 how to program 9C, twin elevator servos with 6ch RX >
Old 01-08-2006 | 04:53 AM
jamesg25's Avatar
Default how to program 9C, twin elevator servos with 6ch RX
Hello all
i need a bit of help i have a razzle and it has two elevator servos. how do you program the 9C withe ailevator because the default second elevator servos is ch 8. how to make it channel 5
thanksregards
james
Old 01-08-2006 | 07:51 AM
DiscoWings's Avatar
My Feedback: (76)
Default RE: how to program 9C, twin elevator servos with 6ch RX
you can do this but you can not trim the elevators once you do this (basically 1 will trim while the other stays at 1 point, its a really wierd mix).
get an 8 channel like hitec supereme and you won't have any problems.
Old 01-08-2006 | 10:11 AM
teeps80's Avatar
www.futaba-rc.com/faq/faq-9c-q512.html
Try this channels 2and 5.
Old 01-08-2006 | 11:36 AM
shakes268's Avatar
ORIGINAL: DiscoWings
That is incorrect. In the 9C, you can change the channels in the mix - which one is master, which one is slave. In the 9C, trims ARE slaved in the dual elevator mix. In the 7C, they are not.
With a 6 ch. receiver however, you will have to run the Y on the ailerons.
Old 01-08-2006 | 12:56 PM
what do you guys suggest is a reliable gas engine in tjhe 50 to 60cc category?
Old 01-08-2006 | 08:25 PM
jamesg25's Avatar
why would i have to use y harnes for ailerons?
channel 1,6: ail
channel 2,5: elevator
channel 3 : throttle
channel 4 : rudder
...-_-
i still dont get, how do you utelize the mix what should i substitue in place of the example of 2 and 7 by futaba
thanks regards
Old 01-08-2006 | 09:50 PM
daveopam's Avatar
My Feedback: (9)
First go to
*AUX-CH in the basic(acro) menu.
Make CH5 read NULL
Then go to a program mix. (I use 3) and set it up as follows. MIX>ON MAS>ELEV SLV>GEAR LINK>OFF
TRIM>ON SW> dosnt matter just pick one POSI>NULL
Then go to the other page and make both your rates 100% Depending on your servo position the could both be + or - 100% or one of each. This should do the trick.
david
Old 01-09-2006 | 05:47 AM
jamesg25's Avatar
YES that did itut i had to make the LINK>ON not off
thank you sooo much
Old 01-09-2006 | 11:56 AM
shakes268's Avatar
ORIGINAL: jamesg25
channel 1,6: ail
channel 4 : rudder
...-_-
thanks regards
So you have a 7 channel receiver?
1
2
3
4
5
6
B
2
3
4
5
B
Battery is normally included as a channel - when you go to Futaba's website, notice an 8 channel receiver has channels 1-7 and then a B channel for battery. That's why as I said you would need a Y Harness for ailerons. If you indeed have a 7 channel receiver you're fine.
