 Edge540 26cc >
Edge540 26cc
Edge540 26cc
Old 11-10-2006 | 10:19 AM
  #151
Default RE: Edge540 26cc
I have ordered mine yesterday [8D]
I will mount an OS 160Fx+Pitts on it.
Have everybody respected the recommanded CG ?
Old 11-10-2006 | 11:23 AM
  #152
You will receive a manual with the exact position.
Old 11-10-2006 | 11:27 AM
  #153
Is this position correct ?
Old 11-10-2006 | 11:56 AM
  #154
I think so! I am flying very well!
Old 11-12-2006 | 06:14 AM
  #155
My friend flying.
http://www.rcuvideos.com/view_video....ype=&category=
Old 11-12-2006 | 03:06 PM
  #156
Banned
"This video does not exist"
Old 11-12-2006 | 06:39 PM
  #157
My Feedback: (66)
I am flying mine with the 26cc and have no problem pulling out of a hover. One thing I think most people are over looking is this engine is two rings on the piston instead of one which = the more gas thru it the more power it's going to make will take a long time to break one in good.
Old 11-13-2006 | 02:36 AM
  #158
For the video, look at http://www.rcuvideos.com/view_video....0e47ae9118d864 and http://www.rcuvideos.com/view_video....3ad173e2f53575.
Old 11-13-2006 | 09:05 AM
  #159
Well, I would think the video is proof the SPE will pull out of a hover. My wings should be here is a day or so, then I guess I will know for sure. I use Klotz mix in all my gas engines. I have seen that DA and other use regular lawnboy mix. THe Klotz is a little messy, but is the best mix IMO as it is 100% Syn. What is the benifit of the other mix, ratherthan saving a couple bucks and less mess. I would think one would use the 100% SYN to get more protection and less wear.
Old 11-13-2006 | 09:58 AM
  #160
I have two questions I would have response concerning this plane as I still don't have received it.
What size of spinner should I buy for this plane ? 3" ? 2"3/4 ?
What throw do you use on aileron, rudder and elevator ? What are your dual rate trow?
Whith these information, I could order the good spinner now before receiving the plane and I could build the plane as soon as I will receive it.
Thanks for your reply
Old 11-13-2006 | 11:52 AM
  #161
From: Povoletto (Udine)Friuli Venezia Giulia, ITALY
Which prop on that videos?
Bye.
Andrea
Old 11-13-2006 | 12:04 PM
  #162
AcroJo's Avatar
ORIGINAL: freebird1
Lawnboy, 'ashless' oil is used for breakin when seating the rings. I run a gallon of that mix before switching to synthetic. Some run two or more. You can breakin on synthetic, but it will take many gallons to seat the rings. I only use 3W synthetic after breakin. Joe
Old 11-13-2006 | 04:02 PM
  #163
Banned
Is there a cooling problem with those engines/models? Lots of the vids show them flying without a cowl.
Old 11-13-2006 | 05:15 PM
  #164
My Feedback: (66)
NO cooling problem, if you look at the one with a cowl you will see how much of the bottom of the cowl is cut out. Ok Folks I will have my test engine this week and plan on flying it over the weekend. If all goes well we will be selling the engine in about 3 weeks. I also will have the Edge, Yak and Extra 260 all in the 26cc class in late Dec. Here are a few pictures. Our Engines will come with a wrap around pitts muffler and a rear mounted carb.
ID:	559644   Click image for larger version
ID:	559645   Click image for larger version
Old 11-13-2006 | 05:20 PM
  #165
My Feedback: (66)
Picture of the engine and a picute of a test 26cc edge form another company. If this one flys good I will have in RED and white , and yellow and white. You can give me a call at 662.347.2042 if you have any questions or would like to get on my waiting list.
ID:	559647   Click image for larger version
Old 11-13-2006 | 05:47 PM
  #166
beautifull Extra 260[8D]
Old 11-13-2006 | 08:04 PM
  #167
My Feedback: (23)
Hello everybody, i make that 2 edge video, and just want to post here my setup:
peakmodel edge 26cc
26cc rear carburator engine (no brand on the engine, it was sent to me for testing, i do not know who is the manufacter)
apc 17x6 prop 8100 rpm
4 futaba s3305 servos
1 standart servo for acelerator
6v 1300mah nimh batery
Have not weighted the model, sorry.
Very good airplane, for 3d flight and precision, lots of wing area, top quality construction.
Hope that helps
Jose
Old 11-14-2006 | 08:03 AM
  #168
Is it just me, or does the YAK not look quite right? There's something odd with the cowl.
-R
Old 11-14-2006 | 08:16 AM
  #169
My Feedback: (66)
What are you looking at? The Yak is a fun scale, it is round like a yak but I don't think it is scale, also the Yak has a much bigger fuse then the edge. I will try to take a few pictures of the one I have now and post later this week as I am off to work for a few days now.
Old 11-14-2006 | 08:25 AM
  #170
OK - I didn't realize the Yak was "fun scale". The Edge is clearly and Edge, but the Yak, I had to think about it.
I've been thinking about ordering the Combo for either the Yak or the Edge, but suddenly, there is now an Extra 260 somewhere in the works .... decisions, decisions, decisions ...
-Rick []
Old 11-14-2006 | 10:22 PM
  #171
ya tell me about it I had my finger on the purchace button but that 260 looks great.
Old 11-14-2006 | 10:40 PM
  #172
got my wings, so should have her flying soon.
Old 11-15-2006 | 07:53 AM
  #173
Have received the EDGE yesterday, Tuesday.
I've ordered it thursday, it has been sent Fryday from China and arrived very quickly.
That's great. No custom charges in France. No damage inside. Everything is OK.
The only question I have is if the tank cap is compatible with Methanol or only with Gass ?
Can anybody tell me if I have to change the tank or tank cap to make it compatible with Methanol ?
Old 11-16-2006 | 01:22 PM
  #174
yallaair's Avatar
Hi
I' have the EDGE 540 with a SPE 26cc. Tested two different engines from peakmodel and both having the same problem. After approx. 2 running hours it seems that the supplied ignition fails and engine refuses to run at all. It will fire and run for a couple of sec but stops again. Tested with all different needle settings and different fuels, different carbs, battery packs, plugs etc. Nothing mechanical wrong with the engines. Suspecting the ignition module to be broken. Is there anyone else that has experienced the same problem?? Don't think this is just a coincidence since I have received TWO different engines from Peakmodel and both are having almost the same problem...
Old 11-16-2006 | 03:06 PM
  #175
Banned
Did you gap your plugs prior to use?
