Peakmodel Extra 260 25%
#327
ORIGINAL: Canadian_Eh!
i have the OS120AX in a peak models yak, and yes it has plenty of power, so it should have plenty of power for the extra too, but im below sea level, so if your at altitude it might be a different story, however heres the link and you can see for yourself
http://www.youtube.com/watch?v=ioK9sahnvzY
#328
I've been doing a bit of background reading before I pull the trigger on one of these combo's. I've settled that the Yak is the model for me, but the engine is taking a little longer.
The spe is also sold by cermark,(as are some of the kits), and have been reported by some to be reliable but a bit lacking in power.
The Peak 26cc is also sold under different badges as SV, LS and I think Grp pro and from the comments I've seen, again are quite reliable and offer a bit more power than the spe.
Based on this I am ruling out the spe, but I have yet to find anyone who can give a direct comparison of the Peak / sv / Ls and the crrc engine also on offer.
The only thing swaying me is the fact that there is a Peak/extra combo at my club which is going well. So I may follow suit.
Iain.
Iain.
#329
Hi,
Finally the weather was fine this tuesday! It flew perfect!!
I had the CG about 1 cm in front of what was recommended in the instructions and it needed a couple of up trim and a few right aileron to fly straith.
I have a Moki 180B gasoline engine in it and there was PLENTY of power!
Final weight with empty tank was 5100 gram.
Thomas Pedersen
Thomas Pedersen
#330
TX, HUNGARY
Hi Chap,
Congratulation to your success.Mine is also ready for the maiden,I already started the Airworld Moki 1.80 gasser.What a nice engine.
Pls post some pictures about your plane.
Georgee
Georgee
#331
ORIGINAL: altidsulten
Hi,
Thomas Pedersen
Hi,
Thomas Pedersen
#332
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
extra 260
weight 4.1kilos -9.03lb
engine. OS120 ax
2. hitec 5625 ailerons
2 .jr 821 doual elevators
1. futaba 3305 ruder
1.hitec 425 throtle
prop. xroar 16x6
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#333
The EXTRA 260 25% flew this weekend .all went fine no problems and the 120 ax is more than strong for the 4.1 kilos off the plane . i set the C.G point at aboyt 135 mm and i still need down when im inverted....ill see about it in the future ,i want my planes to be tail heavy so.....OH and this plane is so easy to hover and torqe
im happy i bought it again
#334
and a small video off the extra ....
http://www.youtube.com/watch?v=N7Q_dDqOs34
#336
Can we get that color here in the US???[X(]
That kicks so much azz![8D]
Very nice Aandreas...I appreciate
the fact that you are keeping the
good 'ole 2-stroke alive. I can't
possibly imagine the benefit
of a larger, heavier and more expensive
4s or gasser in this model except
for the braggards!
for the braggards!
#337
im having so must fun with the 260 and it is so easyer to get it in my small car
..simpe glow power no pumps no 4 stroke expensive YS just hummer the elevators and go 3D.a friend off my is building another at the moment so when his engine is broken in we will fly together and it will be on camera i hope.
#338
ORIGINAL: aandreas
After seeing your video I decided to install an OS120AX into my Extra 260 which used to have a SPE40.
Sold off the SPE40 and was going to sell the airframe but thought I would put a new life into the plane and keep it super light with a glow engine.
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
#340
ORIGINAL: aandreas
I think that you will be very happy with the extra and the 120 !!!!!!!
Thanks Andreas
Where did you mount the fuel tank and throttle servo? (any pics would be great)
#341
HI ! i mount the tank on a peace off foam at the most front position behind the round holl at the firwall.the throtle servo is st he right in front off the wing toob i ll put same photos tomorow
#347
ORIGINAL: aandreas
well it looks like they dont for the time ...
Any pics of your cowl install would be great.
I am installing the Sullivan On Board Glow system so hopefully I wont have to cut much of the cowl.
#349
Flew the Extra 260 with the AX120 today!! Love the engine!
Started first flick and never went deadstick. Have 5 flights on it so will put another 5 flights and start leaning out. Flew with a APC 16x8 but will try the APC 17x6 that most say works well.
I just have a gap around the pitts muffler and slightly over sized to allow hot air to escape. Hope this will be enough.
Got my Sullivan on board glow today from Tower but not sure if I will use it on this plane as I want to keep it light for 3D.
I ran it in on 20% nitro as thats what I had but I hear 10% or even 5% is better. true?
#350
the 120 will work fine with 10% or 5% i prefere 10% .20% i think is more than is the motor will like...allso you must heare knocs with 20%?
