Which G2 plane for elevator, harrier? >
Old 04-24-2003 | 09:55 PM
Default Which G2 plane for elevator, harrier?
I have had great luck with learning to hover with the G2 plane "Cap 232 - 2x" which is very easy to hover.
I have not had much luck with elevators or harriers with this plane. Is there a G2 plane file that works well for a harrier/elevator trainer? If so, where do I find it?
Leonard
Old 04-24-2003 | 11:06 PM
The only plane that i have flown on g2 that will harrier is the ZNline 300. You can get it from aero3d.net.
You still have to do some tweaking to the control surface's ad its not really realistic but it can do it.
Old 04-25-2003 | 12:48 AM
almost all my planes do, Ill send any of them to you, i have all add ons
Old 04-26-2003 | 04:52 PM
To da King how is the ZN line extra that you downloaded from aero3d.net. What did you do to tweak it?
Old 04-26-2003 | 07:45 PM
Default Re: Which G2 plane for elevator, harrier?
Leonard
Hi jldecarlo:
I also use this plane on G2, and I can harrier with it. The CG is about -4, and the surfaces are turned up pretty high. I think I'm using the OS 1.60 for the power....but I'll have to check.
Old 04-27-2003 | 10:42 AM
I know i played with the throws and the cg but other than that i cant remember. sorry.
