 Pull  Pull  Slack >
Pull Pull Slack
Pull Pull Slack
Old 05-25-2008 | 08:41 PM
GregT882762's Avatar
Default Pull Pull Slack
I have a 74 in yak that after 12 flights ive had to tighten the pull pull cables afters every 2 or three ,is this a normal stretching period,how long should i have to do this the wires are crimped backed through the sleeve with a loop like most suggest,just curious,wish it just had a servo mount with a rod,its an EXtreme flight yak 74
Old 05-25-2008 | 09:54 PM
broke_n_bummin's Avatar
Default RE: Pull Pull Slack
I've never had to retighten them. Are you sure all your crimps are tight? I usually give a sturdy test pull just to make sure they're tight. Also, if the cable has any twist in it, the vibration could let the clevice loosen or tighten up.
Old 05-25-2008 | 10:13 PM
MetallicaJunkie's Avatar
ive never had yo either... you might what to make a reference mark, and see if it shifs
Old 05-26-2008 | 01:48 AM
you should check to make sure these wires arn,t cutting into some wood sections somewhere in the fuselage or where they exit. normally when these wires are crimped and tensioned they stay tight, if in doubt you should replace these with my favourate wire which is nylon coated fishing wire trace plus the crimps are long and strong.
Old 05-26-2008 | 11:38 AM
My Feedback: (23)
extreme temperature differences can also change the tension a bit, of course it will go back when the temperature returns. My planes usually do take a couple rounds of re-tightening, my loops are a bit large.
Old 05-26-2008 | 12:25 PM
My experience has been that they come "unwound" if they are not tight enough. With the setup I had on my YAK, you had to twist the wires to tightened the pull and they where left with a tension to untwist, if that makes sense. To prevent this I think you need a turnbuckle. - That is what I was going to do but I finally wrecked the YAK instead.
I would be interested to hear how other people set up their pull-pull. I may eventually fix the YAK.
