Great Planes Reactor 160?
I really am starting to like this plane. It is just so much fun to fly. I'm still considering wheither or not to leave the tail weight off.
One of the best things about this plane is it's ease of landing and overall confidence inspiring flight characteristics. It doesn't do much to give you concern.
My (like others) seems to drop a wing a bit if you "slam" into a wall. But only if you are going very slow. And even then it's not problematic. Just adjust with the rudder and continue on.
Like my UCDs this plane is all about having a good time flying. Just nothing to worry about and easy to fly and a lot of fun.
My DA 50 seems to be a perfect match power wise. My carbon fiber wing tube seems to be holding up great. I'm getting braver with the violent moves trying to test it a bit. I'm doing full on "blenders" now without any problems and it really stresses the airframe when you do them. Also, so hard fast walls, and some snap rolls that are pretty impressive. I don't think the wing tube is going to be an issue. I'm just gonna fly it like I would with any configuration and see how she holds up.
Anyways, very satisfied with this plane. Gonna be a favorite.
Barry
I flew my Reactor 4 more flights last Saturday. I had removed .8oz of weight from the tail prior to these flights. It helped quite a bit in KE flight but still have moderate coupling to the canopy. It is slighty harder to hover but still pretty easy. Waterfalls, and flat spins seem uneffected.
Barry
The wing tube I ordered is JAE.875x30 (F101A) $19.99. Mine was a tight/snug fit but went in with no problems. Since I've got 20 or so flights on her the tube is looser but still pretty snug. I'd call it a perfect fit,,,now. It's a very thin wall, but like I've been posting....no problems, yet.
Barry
I got my wing tube at TBM. It is over 7 ozs lighter than the stock one. I was a bit surprised though...everybody's been saying their planes are coming in right about 16lbs. So....I expected mine to be about 15.5lbs. Well I'm right at 16lbs so I'm not sure what is going on with that.
Barry
Even had a real bird come in for a visit between flights.
Have to agree with Barry the Reactor does inspire confidence, this plane is great
I got my Reactor out for one flight today, pretty windy, and the sod cutters were busy. I had to fly off some relatively tall grass to avoid the sod cutters, and the noticed the plane had a little tendency for the tail wheel to bounce up a lot of the ground even with full 3D elevator deflection. It's ok on our regular grass. I commented before that the elevator low rate deflection wasn't enough, well the aileron low rate isn't enough either. No biggy, minor radio change. So far so good after three flights, but need some calmer weather to start to dial it in. The DL50 provides tons of vertical.
I do have a question on landing. Because our field is a little short, I find I have to bring the plane in relatively low to be able to flair without running out of room, and because of ground obstacles, this can shorten expiration dates. I'm used to a Sukhoi and Ultimate that have wide bodies requiring a little throttle to land. This plane doesn't have the frontal area and doesn't want to slow down very fast. So with that and the low wing loading it wants to float on by. This was a problem today even with a stiff head wind. How do you guys get it slowed? The idle is as low as it goes with a 22x8 prop, the issue is my technique. There were comments earlier in this thread about the plane landing like a cat with sore feed, this is very true. It sets down nice and easy, I just need help to slow it down because of the short space.
Chuck
Chuck
ALSO>>..........I am very confident that the anouncment of this bigger, but small ractor bipe, will lead to a 1.60 Sized BIpe!!
If they follow the trend they have been doing with the reactor series....Can't wait.............
Chuck
Notice the thru bolt next to the black screw these thing do not come off , you can even see the scratch marks at the split where I had to pry it apart to remove it once.
Troy built models sells them
How do you guys tighten you wing screws? I tighten them real tight with my fingers, but they still have a tendency to loosen up. Also, what is the best way to laterally balance the plane?
I exchanged my wing bolts for these. http://www3.towerhobbies.com/cgi-bin...?&I=LXJUP0&P=7
They are much easier to tighten down and I haven't ever had one come loose.
A way to get pretty close on lateral balance is to tape the rudder so it can move and be sure your tail wheel is as straight as you can get it. Then turn your engine so it is "off" compression and lift the plane with the propeller tip. If the plane falls to one side it is heavy on that side. I do this several times to verify which side is heavy. Than add weight to the other side until it stays stable without falling one way or the other. This should get you close enough.
Another even more accurate, but more difficult as well, is to hang the plane upside down ( usually do this in my garage) and use light wire or fish line. Again with the rudder taped so it can't move run the line right around the base of the tailwheel mount and around the prop hub shaft ( I usually take the prop off for this) and then lift it up. It will fall to the heavy side. Add weight to the other side to get it balance.
On my Reactor I thought I had a lateral balance problem because it seemed to drop a wing in walls and a few other maneuvers. But when I did both balances I couldn't get it to drop one side or the other. It seemed perfectly balanced as near as I could tell. So I just entered the maneuvers slightly faster. I think I was actually stalling one wing sometimes.The extra speed seems to help quite a bit. No more wing dropping.
Anyways, either of these balances will get you very close.
BArry
Those UCan Do wing bolts look like a good idea, I have been using a dime in the slot to tighten mine
Barry
As far as lateral balancing I have one thing to add...Trying to use the engine shaft is not a great idea because most of the time the engine is at an offset due to having right thrust built in, so the best place to balance from is to use a screw in the middle if the firewall as it will be in the true centerline of the plane....
Sad in Minnesota,
Chuck
Has anyone flown the smaller reactors? I was thinking of buying a little one and doing it electric....
Both are excellent planes, highly recommended.
guys inspect your ribs in your wings. look at the passage way the aliron leads go down. My reactor has every rib broken!!!! I have 20 flights on it and am lucky I found the problem on the ground as in the air would have been sad. I have flown my plane very conservative, hoovers, waterfalls, knife edges. I did a few snap rolls the last day but they where all at half throttle. Anyways guys check your wings carefully!!!! I have written GP and would be interested in your findings on your planes!!!
Thanks for the info on the carbon wingtube. I dropped 9.4 ozs by swapping it out and my all up weight now is 16lbs 4ozs confirmed on a digital postage scale...The old tube weighed in at 11.4oz and the new carbon tube is only 2.0ozs!!!
