U Can Do 3D
IL
Tower hobbies Super Saver flier came out today and the U can do .46 is on the cover for $144.99. Although it is posted late may arrival, which I believe this is as late may as its gonna' get!
go to www.towerhobbies.com and in the top-right search box, search for "u can do" ... there you'll see the new u-can-do-40 ... it looks like it has a GREAT wingloading (at only 13+ oz/ft sq) and I like the color trim more than the one on its older sibling the 60-90!
I'm looking forward on hearing flight-reports on this plane
I was flying my UCD the other day, just you basic tearing holes in the sky. I brought the plane around in a low pass, and realized that something was seriously wrong with the landing gear. They were facing 90 degrees the wrong way! One of the screws had vibrated completely out, and the other was just hanging on by a thread. Luckily, I had just finished setting up full flap travel with the airbrake switch. I brought it around into the headwind, which was considerable, and was able to stop the UCD (zero groundspeed) at about a foot off of the ground and set it down light as a feather. I then found some screws, screwed the gear on with toothed washers and split washers and then drenched them in Locktite. Make sure you guys check the tightness of your LG screws.
the color scheme is definitely nicer though.
