 Fliton Inspire >
Fliton Inspire
Fliton Inspire
Old 03-05-2010 | 09:04 PM
Basement Troll's Avatar
Default Fliton Inspire
Is there a set of landing gear I can buy somewhere to replace the ones on my Inspire? Mine have been glued several times and they are broken again. I was hoping I could order a set from the Reactor or something.
Don
Old 03-06-2010 | 04:23 PM
My Feedback: (13)
Default RE: Fliton Inspire
IF YOU'D LIKE I CAN GET YOU THE MEASUREMENTS FOR THE REACTOR GEAR. WOULD HAVE TO BE LATER IN THE WEEKEND THOUGH; UNLESS SOMEONE CAN HELP YOU BEFORE THEN.
Old 03-06-2010 | 09:53 PM
I still have the old stuff, I was just wondering if I could buy a set that would fit the plane without major surgery. Does Graphtech make them?
Don
Old 03-07-2010 | 11:12 AM
My Feedback: (13)
ORIGINAL: Basement Troll
Don
Give them a call. If they dont already, maybe they would be willing to make them for you.
Old 03-07-2010 | 04:02 PM
TruBlu02's Avatar
Yeah graphtech makes a set of gear legs for the Reactor. They are pretty nice but they do tolerate alot of abuse. The redesigned stock Reactor ger is tougher but it wont be as light.
Old 03-08-2010 | 08:09 AM
Thanks Guys, I'll give Graphtech a try. I think I can make the Reator gear work.
Don
Old 03-08-2010 | 08:54 AM
My Feedback: (13)
Im thinking you could use the same method used with new engine mounts. Remove the blindnuts with heat, fill the hole with dowel and epoxy. Sand flush, redrill for new blindnut location, install blindnuts - and done. Shouldnt be difficult.
Old 03-08-2010 | 01:40 PM
ro347
That's a good idea. I may just do that itf the geas shows up with pre-drilled holes. If it hasn't bween drilled, I'll just match the holes up.
Thanks for the idea.
Don
