RCU Forums - View Single Post - 8ight keeps trashing servos
Old 07-09-2007 | 07:49 PM
gtsum
Default RE: 8ight keeps trashing servos
This is what you need:
http://www.rcuniverse.com/forum/m_47...32/key_/tm.htm
Scroll down until you see the pics and follow them. Servo's burning out are 100% user setup error. Take your time, follow those instructions and also the Losi addendum and you will be fine...setting this up correctly (the first time) will take quite a while...I used the above link as the addendum was not out yet when I built mine...I bet I was fiddling with it for 2 hours before I was happy with it....5 gallons later, and I have not had a single servo issue (nor has anyone else that i helped set up)
