RCU Forums - View Single Post - Blade Cx2 turning problem
Old 01-30-2008 | 05:16 PM
eat2muchrice's Avatar
eat2muchrice
Default RE: Blade Cx2 turning problem
Its the Blades. Check your blades again. Also make sure you balance and track them.
Eat2muchrice’s Warped blade test
http://youtube.com/watch?v=_7PwNTXOWMs
Eat2muchrice’s Blade boil fix
http://youtube.com/watch?v=RmNv8OlG6GQ
RCFEIND’s Balancing Blades
http://www.youtube.com/watch?v=15h9G...eature=related
If that doesn't fix it then check for bent shafts and bad bearings.
Quattro1975's Bents Shaft Repair
http://www.rcuniverse.com/forum/m_6791546/tm.htm
If you still have the problem then its probably your motors. How old is it?
