RCU Forums - View Single Post - help
Thread: help
Old 02-28-2008 | 11:32 PM
sheograth's Avatar
sheograth
Moderator
Default RE: help
I have a Mini-Baja, which is a bit different electronically but should give you some idea of what to expect. It's all stock. The battery is an 1.1 amp hour NiMh, and I charge it at 1.5 amps takes just under an hour to peak generally. Run times are like 20 minutes or so with the way I drive...
