help
You may want to do a search in the mini and micro forum for this question. They would be better suited to answer this for you, and more than likely you can find it in a search faster than making a new thread about it.
I have a Mini-Baja, which is a bit different electronically but should give you some idea of what to expect. It's all stock. The battery is an 1.1 amp hour NiMh, and I charge it at 1.5 amps takes just under an hour to peak generally. Run times are like 20 minutes or so with the way I drive...
ORIGINAL: hands without shadows
I get about 20 minutes out of an IB 1200 6 cell pack with a Mamba 6800 combo. About 35 minutes with a 2s 1350 mah lipo.
i get 30 - 40 minutes every time
on a 1250 / 3s
in an rc18b w/ mamba system
15 - 20 min with a nimh
and you really shouldn't charge much faster than an hour
if you want the batteries to last anyway
