RCU Forums - View Single Post - engine problem
Old 05-04-2008 | 08:12 PM
sheograth's Avatar
sheograth
Moderator
Default RE: engine problem
Check your idle adjustment screw and/or the throttle linkage and trim. Basically you want to make sure that the carb is NOT being fully closed when it should be idling. With the engine off, remove the air filter and take a peek. At neutral, the carb should be cracked open a bit to allow an idle.
