RE: wheel rim combo for baja 5t
I'd avoid alloy rims unless you're going for looks and will be running mostly on road. They're heavy, expensive, and you'll get mad when they get scratched up.
I've found the proline wheels to be a bit stronger than the stock ones, and either are cheap enough to replace as needed.
