Custom prop nut pics for Capn John!
Old 03-10-2004 | 10:16 PM
av8tor1977's Avatar
Default Custom prop nut pics for Capn John!
Hi,
Here's those pics finally. The one pic is of one of those long necked nuts that originally went to the weedeater cable. I cut it down slightly, and drilled/threaded it all the way through. Then I drilled the prop out slightly larger to accomodate the shoulder of the nut, and put the nut on "backwards", so that the neck, or shoulder, of the nut went through the prop. The other two pics show the rest.
The sleeve with set screw that you see, is something that I picked up at the hardware store. After I cut the center out of that particular flywheel to use to mount the magnet, it turned out to be slightly small in diameter. So I found that sleeve with set screw at the hardware store, and used it over the top of my custom hub, and mounted the magnet to it.
Hope it all makes sense,
Take care,
AV8TOR
ID:	110125   Click image for larger version
ID:	110126   Click image for larger version
Old 03-12-2004 | 08:56 PM
Default RE: Custom prop nut pics for Capn John!
HI AV8tor: Looks like a good idea. I thinking maybe all of us could turn this series of posts into a picture collection of all good ideas RCer,s could get too all in one place. The engine in the mill has Zenoa 1490 on the cyl base. (red max?) The engine on stand is a Poulan 46cc. The other photo is a close up of how to make a carb vent tube. Thanks Capt,n
ID:	110819   Click image for larger version
ID:	110820   Click image for larger version
ID:	110821   Click image for larger version
Old 03-12-2004 | 09:10 PM
av8tor1977's Avatar
Hey, nice pics, and a good idea. Let's go with it!
What size Poulan is that and do you like it? I have both a 36 and a 42cc Poulan that I haven't finished converting yet.
Take care,
AV8TOR
Old 03-12-2004 | 09:18 PM
More engine photos The top photo is a 46cc Poulan with RCIGN ignition system. The third photo is a Ryobi running on glow.
ID:	110826   Click image for larger version
ID:	110827   Click image for larger version
ID:	110828   Click image for larger version
Old 03-12-2004 | 09:29 PM
The Poulan is a 46cc. I hear they are very good. The engine in the mill is mine (a red-max) the other engines are some I liked and stored the photos in my computer. What do you think. Some folks may like this...no arguments...but a lot of data. A picture is worth a thousand words! By the way I got a few more engine photos (some mine)I will post, if people like!!! Capt,n
Old 03-12-2004 | 09:45 PM
av8tor1977's Avatar
Ha, what a grin. That pic of the "JATO TUBE" exhaust on a Kioritz it mine! Cool!
Hey, check out my "The Phoenix" post and let me know what ya think.
Take care,
AV8TOR
Old 03-12-2004 | 09:51 PM
av8tor1977's Avatar
Default ENGINE & HARDWARE PICTURE POST
Come on everyone, this could be cool...
More pics please...
Have fun,
AV8TOR
Old 03-13-2004 | 11:20 AM
Default RE: ENGINE & HARDWARE PICTURE POST
When posting a photo....please post it in the Engine & Hardware post...so all photos are in one place. Thanks Capt,n I was hoping the Moderator could help us place all the photos in one forum.
Old 08-10-2004 | 05:43 PM
Captinjohn
How much rpm and thrust did you get with the Ryobi on glow???
Nice challenge, did it become a kicker??
How much fuel does it consumes per minute??
I think around two ounces per minute or more right??
I´m sure the ryobi on glow is a great engine.
Did it uses the standar carbuertor or must be modified/ replaced??
Hope for your info.
Tatolazo
Old 08-10-2004 | 07:53 PM
The engine on the stand is the 42cc Poulan. With a different muffler it turns a MA 20x10 at 7360rpm or a Pro Zinger 20x8 at 7560rpm.
Old 08-10-2004 | 10:59 PM
My Feedback: (84)
Flip flop, what muffler are you refering to on the 42 cc poulan? thanks
Old 08-11-2004 | 06:51 AM
I've run it on the mufflers from Abel r/c and B&B. Performance is the same.
Old 10-05-2004 | 10:43 PM
TATO.....I did not have a Ryobi yet. I think they are ok though!!! Capt,n
