GSP Zero
Old 06-21-2004 | 06:12 AM
SJN
Default GSP Zero
I just bought a ZERO!!!
wow it looks good :-)
What engine are you guys using?
Ive got a webre 91 P5 aero that swing a 14/7 prop nicely. Will this do ?
Do you like yours ?
ID:	145603   Click image for larger version
ID:	145604   Click image for larger version
ID:	145605   Click image for larger version
Old 06-21-2004 | 06:13 AM
SJN
Default RE: GSP Zero
ID:	145607   Click image for larger version
ID:	145608   Click image for larger version
ID:	145609   Click image for larger version
SJN
ID:	145611   Click image for larger version
Old 06-21-2004 | 08:43 AM
SJN
ID:	145653   Click image for larger version
ID:	145654   Click image for larger version
Old 06-21-2004 | 09:32 AM
Looks Great SJN,
I have one which is still in the box lol, its 4th in line i need to build my Wild Card first then my Flair/GSP Spitfire then my GP ShoeString Racer then the Zero......... then my Rapier then my Bearcat then my P38 Jet etc etc just not enought time in the day lol
Kinda feel sorry for my Zero Pilot hes thier wating to fly but is currently grounded due to lack of time lol.
Please keep us informed on the build i would love a step by step of when u do ur retracts, as i havent fitted retracts before and it would be extremely helpful if u can take a few pics
Ps : I was planning on getting a Super Custom 120 Four Stroke in.......
Many Thx
Old 06-21-2004 | 10:58 AM
SJN
Well, this is how it looks now.
Im using eurokit air/spring retracts, and they are 25mm wide, where the mounts are only 20mm wide.
I have then removed 5mm of the mount to fit the unit.
I have to order some longer and a bit different lookin oleo strust so it will look good.
The 6mm steel pin that connect the strut to the retract unit has to be bent forward so it all fits nicely together.
Do you guys thenk the 90 is too small?
HAve a look at the specs: http://www.webra-austria.at/motor.ph...r=AERO&lang=EN
Old 06-21-2004 | 01:07 PM
SJN
borrowed the oleos from my eurosport jet just to see how it looks.
The ones I have ordered are longer.
When I first bought the plane I thought I neede to get 120 degrees retracst to fit the wing properly.
But standard 90 degree`s work fine [8D]
ID:	145731   Click image for larger version
Old 06-21-2004 | 02:50 PM
SJN
ID:	145886   Click image for larger version
ID:	145887   Click image for larger version
Old 06-21-2004 | 04:18 PM
SJN
ID:	145908   Click image for larger version
Old 06-21-2004 | 04:26 PM
Looks Great SJN, u work fast
Old 06-21-2004 | 04:40 PM
SJN
Nah...havnt realy glued anything together yet....other than the firewall.
It realy is an ARF
Old 06-21-2004 | 05:27 PM
Those Yellow wing stickers are a pain to get on, i remember having problems on one of my spits lol..
Do u use the windex/soap method or just stick them on and prey lol
Old 06-21-2004 | 05:47 PM
SJN
nope...I dont use all that stuff.
Im just good at eye-balling :-)
The yellow stripes, you can just stick them gentaly at each end on both siden of the wings, and see If they match up. If its all lined up, then rub them on. If not, just lift it off again gentaly, and stick them on lightly again until you are satisfied.
Old 06-22-2004 | 08:13 AM
SJN
gluing the tail.
Old 06-22-2004 | 01:03 PM
SJN
Old 06-22-2004 | 01:29 PM
SJN
ID:	146269   Click image for larger version
Old 06-22-2004 | 01:40 PM
SJN
ID:	146275   Click image for larger version
Old 06-22-2004 | 03:41 PM
Wow, it's looking really nice. I am starting to be a real fan of these CMPro warbirds! How is the hardware? Not familiar with the Webra engine. What is this comparable to? I assume it is 2 stroke...? Should be plenty. I plan to fly my GSP Spit with a TT 91 FOUR STROKE! I am not concerned with power.
I feel a 4 stroke does give you more flyability though (more usable rpm range, broader power curve, etc.) even though it has less overall power. Thunder Tiger .91 FS, I hope will be a great engine for the Spitty, since it weighs a ton and has gobs of power -- both things a warbird needs in the nose!
Old 06-22-2004 | 04:08 PM
SJN
Yea, It looks realy nice. I think its a great deal for low price ofthis plane. Im pleased.
The stock hardware is the same as all other ARF`s. Ive never had a problem with it, even though many say it is junk.
The webra engine Im sure will fly this plane in a scale maner. It wont be vary powerfull :-)
I dont know what to compare the webra too. But its one powerfull 91 2st. !
it says 108 2st and 120 4st on the box.
This is quite a large plane.
With my heavy 91, it is still tail heavy.
Im going to build a battery box over the engine, and use heavy 2400 batteries.
Did you see the review of the spitfire ?
http://www.rcuniverse.com/magazine/a...article_id=117
Old 06-22-2004 | 04:40 PM
SJN
Old 06-22-2004 | 04:58 PM
nilo's Avatar
Which kit is this one?
Nilo
Old 06-22-2004 | 05:07 PM
SJN
giant scale planes , CMP , Flair....... all the same
I bought mine in germany, it has no company label on the box.
Old 06-22-2004 | 05:14 PM
Yes mines the Flair Zero - Just hoping it will fit in my audi.......
SJN how much was yours ? mine was £249.00 which works out about 2,792.85 DKK Denmark Kroner
Old 06-22-2004 | 05:23 PM
SJN
you have been shagged :-)
http://shop24.derschweighofer.com/shop/index.html
260 euros, 1950 DKK, £175
Old 06-22-2004 | 05:33 PM
lol yeah we get used to that over here in the United Kingdom EVERYTHING seems to get us, and if we go for the cheaper option to import we get ripped off by VAT and Customs soo we cant win []
