Go Back  RCU Forums > RC Airplanes > Aerodynamics
Why check CG inverted? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 10-16-2002 | 06:14 PM
Default Why check CG inverted?
Gentlemen,
Why do most instructions have us invert our aircraft when determining longitudinal CG? Why can't I just "jack" it up off the gear to find the balance point?
Fred
Old 10-16-2002 | 06:44 PM
Default Re: Why check CG inverted?
Originally posted by redxfred
Gentlemen,
Fred
Low wing planes are easier to balance inverted as then the weight of the fuse is below the wing. The opposite of is true for high wing planes.
