Secrets of Silk
#52
TX
Ask a simple question and I get a 200+ word verbose rant. If I read between the lines I think the simple answer is No. My only point is that if you have ever used any of these fabrics you would know that their application is pretty much the same whether you use silk, silkspan, Japanese tissue, cotton, Dacron, Stits fabric, etc, etc…
Just as I said before,
by your freakishly open ended criteria, silk includes silkspan JapTissue cotton dacron stits etc etc etc,
I can answer 'yes' when you ask
however, when Hoss or Toolman or ED DM ask if I used silk, using standard criteria for what is silk,
then the answer wouldnt be Yes
now you see the problem with your criteria,
and why we need you to let us know the metrics you intend to use when we answer your questions
#53
Here's the chance some of y'all's been waiting for:
http://www.modelaircraft.org/files/CopyEditor.pdf
Put up or shut up time.....
#54
ORIGINAL: corch
Regards
Frank
Technical Writer
#55
Has any magazine ever done an article on "secrets of koverall"? If any of you can cite an issue I would much appreciate it. I will be looking through RCU as well. Thanks.
#56
ORIGINAL: littlecrankshaf
Has any magazine ever done an article on ''secrets of koverall''? If any of you can cite an issue I would much appreciate it. I will be looking through RCU as well. Thanks.
Regards
Frank
