what 2.4 article
#301
<u>QUESTION FROM TimBle:
</u>"How is a Tx impound going to help?"
The 2.4GHz transmitter impound will help; here is why:
Range decreses as the number of clear channels decreases. Bandwidth drops each time FHSS encounters
a blocked frequency on a crowded spectrum. The crowded spectrum on the 2.4GHz band reduces the bandwidth,
increases the ever present background noise, increases the adjacent channel leakage ratio, reduces the range,
and causes overlapping. Overlapping is a direct interference.
#303
Yaaay, doctorates are pieces of paper that you hang on the wall.
In case of an emergence a doctorate can be used to wipe your A*s but a finger works better.
Experience is what counts.
Did Einstein have a doctorate?
Did the Wright brothers?
Did Tom Gates?
Did Edison?
How about Galileo?
Ben Franklin?
And the list goes on and on.
Did Tom Gates?
Did Edison?
How about Galileo?
Ben Franklin?
#304
ORIGINAL: Dave
Receiver sensitivity, unique coding allows for high signal to noise ratio.
So by what factor is range reduced?
#305
My Feedback: (9)
NY
ORIGINAL: gsoav8r
I dont believe it will be anything higher than 2.4. Microwaves already have a hard enough time getting thru obstacles. 5ghz would only compound the issues. Anything less than 2.4 would be beneficial.
Not necessarily true. It depends on the band and what absorbs it. Seems to me that X-Rays and Gamma rays are way up there on the frequency chart and they don't have a problem going through most materials, especially humans. And no, I'm not suggesting using either of those so don't go there.
As I see it, it appears most of the individuals speaking here are speaking from conjecture and a somewhat simplistic understanding of how it all works. Statements earlier in the thread relating 2.4 GHz to light are just an example of, and please don't take this in an insulting way, the average person's ignorance of what the electromagnetic spectrum actually consists of. For a look at how it breaks down and where our systems appear in relation to it, you can visit this site for quite a bit of info even if you're not a scientist. http://hyperphysics.phy-astr.gsu.edu/hbase/ems1.html#c1
Having been an avionics communications specialist in the USAF, I can tell you that there are many factors that affect the propagation of any type of radio wave: frequency and power level being two of the major elements. On the receiving end, you have sensitivity and selectivity as your two major players. Sensitivity is how low of a signal can be detected and selectivity is how good it can distinguish the desired signal to other similar signals. That's why with the old 72 MHz, the AMA established safe distances between fields.
Today's 2.4 GHz systems eliminate some of the selectivity issues by the bind/link process where a transmitter has a specific code associated with it that the receiver constantly monitors once it is bound/linked to the transmitter. Reminds me of the old "I AM WELL" signals incorporated in older equipment. Sensitivity is the next item and the more sensitive the better. These systems are limited in power, and by nature are very directional. The problem is you don't have a directional antenna to focus the beam at the plane's receiver so you're limited to an omni-directional antenna to transmit the signal in all directions. This means that a lot of radio signal is wasted going of into la-la land and not being detected by your receiver. Right of the bat you're range has been decreased. Not necessarily a bad thing considering the systems are designed to work over a relatively small range (1,000 meters or so).
So where am I going with this discussion? I guess what I'd like to say is this, there are a myriad of factors that will affect any of our radio systems and to base decisions of what is best on sheer conjecture and speculation while embracing ignorance, is counter-productive to say the least.
This thread was opened by a simple comment regarding an article regarding 2.4 GHz and blossomed into a monster with all kinds of comments to and from and at specific individuals. I don't think this should be a Jerry Springer type thread.
Any way, if I offended anyone, I apologize now and if anyone wants to learn more about the electro-magnetic spectrum that surrounds us, check out the link above.
#306
ORIGINAL: PTERODACTYL
http://www.nobelprize.org/nobel_priz...stein-bio.html
#307
ORIGINAL: John Sohm
ORIGINAL: gsoav8r
No offense taken. I think it was I who refered to it as "light"; a gross over simplification as Light is merely a range of wavelengths within the electromagnetic spectrum.
I merely used the reference to illustrate that we are sending signals using a band within the electromagnetic spectrum and that the area of the spectrum used is not the major concern but how the hardware detects what is transmitted and how the hardware discerns the transmission from background noise is what is fundamental to the reliability.
#309
My Feedback: (12)
WI
A good education never hurts, but a fancy degree is not a guarantee for infinite wisdom.
I still did not see any proof or practical test other then what the radio manufacturers already did before they hit the market. Not having any problems is enough proof that I bought a quality radio, which is by all means better than the 72 Mhz system it replaced.
So where are the real problems? If someone is in the market for a new radio, go get a 2.4 system. They are great. Nothing better out there.
And who is Tom Gates?
#310
ORIGINAL: Dave
</u>''How is a Tx impound going to help?''
Hmmm...is the worn out case of impounding 2.4/all radios the real thrust behind this thread??? I think so...
Some see the "frequency bored" as AMA's pulpit/alter for AMA religion at the flying field... If the crowded 2.4 spectrum was/is a real issue, a simple guideline for max number of pilots would suffice...instead radio manufactures have gone to great lengths to dispel that notion.
Yep, more about control than anything else it seems...and I don't mean radio control... Sad
#311
I don't know much about the 2.4 band yet. But Im doing all of the recearch I can on this system.. I do not intend to know everything. I can tell you I know nothing other than how to bind the tx and rx and do all of the set ups on my planes. I like it I do!! But I also love the old 72MHz equipment.. I never had any trouble from the 72 band untill they put the implants in my neck..If it hadnt been for that I would still own alot of 72 systems.. That part I posted about 2.4 being illegle in Japan.. I was told this fron my cousin that also flys model planes.. He is on tore now.. But he was In Japan He told me Futaba 2.4 was not allowed for rc use there.. I don't have a clue if it is or isnt.. Either way it has to work for all of us here in the us.. I wonder if we are trying to use to many systems at once? Could this be what is causing conflict? Should they try to limmit how many people fly at once. Again I have no clue. So I will just wing it see what turns up. All of us are pilots of some sort.. We all have our likes and dislikes.. But we are all in this together.. And I love you all like brothers/sisters. moms and dads.. We will get through this one way or another I'm sure..
#313
ORIGINAL: Oberst
Why, only for him to be dishonest? He's only going to do what ever he can to protect the business. I doubt that he's studied electronic physics like some people I know. Heck, I doubt he even studied electronic physics 101.
Me I studied all about the 2.4GHz and different Mhz systems when I worked for AT&T. I had to attend classes in order to sell phone and landline systems and I had to a get 90% ot better to qualify in my field.
What Dave Horvath and I have written was based on knowledge, more so from Mr. Horvath. I didn't study electronic physics, but I do use common sense and good judgement from what was taught to me when I was at AT&T.
Why the RC boats work with the 2.4GHz is because the operation distance isn't like how we operate our planes. The spectum antenna is above water and isn't submerged. The hull of these boats are made of a different material and antenna is perfectly sealed.
Again it's like comparing apples to oranges.
No, the wireless phone system connects to a tower, then sent to the recieving stations tower using the 2.4GHz on the G system. The Cell phone and old pagers works under the MHz band to a towered recieving station then up to the satellite. Think of it as a triangle network. Usually they operate on MHz clusters to either Cell Sector A or B at the recieving station inorder to connect with the satellite. We stopped using Cell technology in the 1980's then went to TDMA devices at around 800MHz.
At the same time we went to TDMA the local towers then started to brodcast the MHz signals to the recieving stations tower and no longer connected to a satellite for communications speeding up the connection. When we went to CDMA, the radio signal was intensified as a result speeding up the radio waves. TDMA was even faster but had a tendancy for interference.
When the phone companies switched to a G network, G= Ghz, we no longer used the MHz for signal and went to the 2.4GHz. With the 2.4Ghz signal speed was inhanced and other applications like Wifi, text messaging and data plans could be operated at a faster transmit speed. Aka light travels faster than radio waves.
I think I can speak for Dave Horvath when I say we only are warning people so people don't crash their planes because of a faulty RC system. If we didn't care about our fellow modelers we wouldn't be waisting our time. For me and Mr. Horvath it wouldn't be right not to warn people of what we know. We are not getting paid by anyone so we are not tarnished by any corporate influances. We do it because we know it's the right thing to do. Why? Because we care. That's why you are getting faced with the truth. Anyone from Hitec, Futaba, Airtronics and JR will not tell you the truth. Why? Because they have a lot at stake financially including the AMA.
Follow the money people and use your common sense and put 2 and 2 together. Please! We are supposed to look out for one another in this hobby and not listen to those who makes a living off this hobby. They are there to sell and make money including moderators at RCU, without marketing and promotion RCU would be in trouble financially.
Pete
ORIGINAL: warbird72
Hey guy's I just called Hitec.. I talked to Tony.. I hope Mike gets on here and clears this up. He is a good guy and very heplful.. Hope this eases some minds..
Sport_Pilot
Not a telecommunications expert, but I thought that cell phones were called that because the tramsmitting, recieving stations worked a small areas called cells, as you move about the services are transfered from station to station. Satelite phones do not use these cells.
Pete
Radio waves travel at the speed of light!
“Look it up.â€
Makes me wonder if you really know anything at all.
Radio wave, microwave, infrared, visible light, ultraviolet, x-ray, and gamma ray are all lightwaves, the differences is there length.
Pretty sure.
#314
JOHN SOHM IS ABSOLUTELY RIGHT. (Post # 304)
The 2.4GHz wavelength is directional. Since we can not focus a high gain directional parabolic dish antenna
between our constantly moving model airplane and our transmitter, we have to use an omnidirectional vertical
antenna system which has much lower signal intensity. Since we have to use an omnidirectional antenna system,
the electromagnetic waves will scatter and diffract from objects and from the terrain around us. When the diffracted
wave reaches the receiver antenna, it is slightly lags behind the signal which traveled to the receiver antenna in a
straight line that creates interference due to the phase canceling effect.
#315
Wrong!!!
“Look it up.â€
Pretty sure.
ORIGINAL: Oberst
Pete
ORIGINAL: warbird72
Sport_Pilot
Pete
“Look it up.â€
Pretty sure.
#316
ORIGINAL: John Sohm
Today's 2.4 GHz systems eliminate some of the selectivity issues by the bind/link process where a transmitter has a specific code associated with it that the receiver constantly monitors once it is bound/linked to the transmitter. Reminds me of the old ''I AM WELL'' signals incorporated in older equipment. Sensitivity is the next item and the more sensitive the better. These systems are limited in power, and by nature are very directional. The problem is you don't have a directional antenna to focus the beam at the plane's receiver so you're limited to an omni-directional antenna to transmit the signal in all directions. This means that a lot of radio signal is wasted going of into la-la land and not being detected by your receiver. Right of the bat you're range has been decreased. Not necessarily a bad thing considering the systems are designed to work over a relatively small range (1,000 meters or so).
ORIGINAL: gsoav8r
#317
Massive gravitational force can bend light.
A fat man walking in front of your transmitter can not bend light, even though you may think that he is a “holeâ€.
Well maybe if he is fat enough he can bend light.
I don’t know.
Hehehehe
Just having some fun guys.
I don’t know.
Hehehehe
#320
ORIGINAL: HighPlains
Nope, light doesn't bend.
That will be news to most all physicists.
http://hubblesite.org/explore_astron..._mod3_q11.html
http://isaacmmcphee.suite101.com/alb...g-light-a43865
#322
ORIGINAL: Dave
So you assume that there is no error correction or rejection of out of phase transmissions
#323
Multi-path signals arrive at multiple phase angles and intensities, not just a single signal that is in perfect anti-phase as shown in text books. So much so that they tend to cancel out. While you might lose a frame every now and then, the dynamic nature of the model would make that a single frame event.
#324
NC
ORIGINAL: John Sohm
ORIGINAL: gsoav8r
So anyway, I agree with this; "many factors that affect the propagation of any type of radio wave: frequency and power level being two of the major elements."
Given that, historically power output from 75, 72mhz , and 2.4ghz radios have been limited to, what, 1w max?. Even lower in country's outside the US. I think I can make a fare assumption that any new frequencies allocated for RC will also be limited to 1w.
Given the limited power were allowed to transmit, I love to see any reference info that suggest 5ghz can penetrate the typical materials used in model airplanes better than 2.4g or 72mhz. (its amazing how much power is needed for x-ray generation and soft x-rays apparently wont go thru much of anything so I wont go there).
Cheers.
#325
"Light waves are radio waves but radio waves may not be light waves."
By Sport Pilot
Frequency is the number of complete cycles in one second.
Factor
1 KILOHERTZ = 10 to the 3rd power cycles per second
1 MEGAHERTZ = 10 to the 6th power cycles per second
1 GIGAHERTZ = 10 to the 9th power cycles per second
1 TERAHERTZ = 10 to the 12th power cycles per second
By Sport Pilot
Factor
