 throttle setup question >
Old 05-22-2011 | 10:21 AM
Default throttle setup question
I just finished putting togather the hanger 9 twist 40 size, it has a 46 ax on front and a 3004 servo for throttle. what is the best way to setup the throttle? I am using the 10c for the radio.
Old 05-22-2011 | 10:30 AM
scale only 4 me's Avatar
My Feedback: (158)
Default RE: throttle setup question
This is how I do it
1- set throttle servo arm in the middle (90 degrees to pushrod)
2-set the carb at half throttle with the length of push rod,,
3- adjust the "End points"s in the Tx so the servo doesn't bind at either extreme
may have to adjust for throttle trim and throttle stop, but that pretty much it
Old 05-22-2011 | 07:38 PM
My Feedback: (13)
ORIGINAL: scale only 4 me
This is how I do it
3- adjust the ''End points''s in the Tx so the servo doesn't bind at either extreme
Ditto!
