Great Planes RV-4 .60
#104
IL
RE: Great Planes RV-4 .60
ORIGINAL: btflycrazy
did a flame job on the RV-4 turned out alright but it just temporary till i recover the whole plane
#105
It's a way to separate yours from the rest. Dig the angry bird pilot.
Can't understand why GP picked such a boring scheme? I couldn't find a full scale version with that color scheme and that tail number. If I recall, I've seen a photo of the scheme with a different tail number...
#106
IL
ORIGINAL: Maxdog.vf213
Usually hate flamesbut doesn't look to bad though.
#108
My Feedback: (8)
Fly24-7: You won't find a full-size RV-4 or any other airplane with the registration number (N-number) included with this ARF. The number is totally bogus. Firstly, N-numbers NEVER include a dash between the "N" and the number, and secondly, the number NEVER begins with a zero. GP kinda screwed the pooch on that count, but at least they got the plane right.
#110
My Feedback: (8)
No. A bit off-topic, but it's a Slipstream RV-8 ARF from Aztech Aeromodels. I posted the pics because of the "pilot". My GP RV-4 just has the GP 1/4-scale civilian pilot, so I decided to get "creative" with the RV-8. Here is the thread.www.rcuniverse.com/forum/m_10888426/anchors_10888426/mpage_1/key_/anchor/tm.htm#10888426
#117
My Feedback: (8)
I'm glad to see there's SOMEONE out there who's not afraid to put some serious power in this plane. All I did on mine was to put 1/2" triangle stock in all of the joints forward of the rear end of the tank. The Saito 180 is at least as much of a paint-shaker as the DLE30, which was why I added the triangle stock in the first place. Everything is still tight and where it belongs, so it must have worked. An 8-10 oz. tank is all you'll need with the DLE30. Very efficient for a 2-stroke.
#118
NC
next time you have the cowl off could you take some pics i like to see what you did and i heard of some guys putting 50cc in there's lol, I bet that really moves
#119
My Feedback: (8)
OK. Here are some pics of it with the cowl. The installation itself is very straightforward. The standoffs supplied with the DLE30 were used as-is. Because I used the single-bolt prop adapter, the new cowl is mounted about 3/16" forward of where it was with the Saito 180. Without the prop adapter, it was virtually identical in length to the Saito installation.
#123
My Feedback: (8)
Get it from ValleyView RC. Great service and they treat you right. All three of my DLE's are from them and there will be more in the future!
www.valleyviewrc.com/estore/
#125
My Feedback: (8)
Use an 18-8 prop for the first 4 or 5 tanks then go to an APC 16-12 prop. If you start with the 16-12, you may not be able to get the idle low enough to land and still be reliable. 32:1 mix non-synthetic oil for the first 3-4 gallons, then you can go to synthetic 40:1 mix if you want. As long as you're not fouling plugs left and right, you can't have too much oil. Nothing leaner than 50:1 under any circumstances. You will really like the 30 after having used the 20 because the 30 is easier to tune and is not as sensitive to needle settings.
