Reload this Page >
Gee Bee R3 30cc
Gee Bee R3 30cc
Old 03-01-2014, 07:35 PM
  #176
evan-RCU
evan-RCU's Avatar
Ordered, thanks for the input!
Old 03-01-2014, 08:17 PM
  #177
paphman
I've got the one from HK. Heavy aluminum wing and stab tube and no spinner. $50 more for GMP is well worth it.
Old 03-05-2014, 01:04 PM
  #178
ultra6a
My Feedback: (27)
ultra6a's Avatar
Evan, hopefully you will have better luck with yours than I did with mine. Beautiful plane.
Old 03-05-2014, 01:40 PM
  #179
evan-RCU
evan-RCU's Avatar
Henry? I heard yours was very tail heavy making it "hard" to fly, is that correct?
Old 03-05-2014, 02:52 PM
  #180
ultra6a
My Feedback: (27)
ultra6a's Avatar
Evan,
Actually it was not tail heavy. John Anklin and I spent quite a bit of time using his EZ-Balancer to set the recommended CG on the plane (Giant Model Products recommended CG). Ended up adding over a pound of lead to the cowl to get it balanced. Dale flew it twice and had the same issues both times. Plane wanted to roll to the left when landing, and always went to knife edge when making aieleron turns. The next time you see Dale you may want to ask him what his thoughts are on correcting the issues he experienced when flying it. I basically gave it to Max who now wants Dale to maiden it for him, but I don't think he really wants to try flying it again.
I'm not sure if it was something wrong with the way I assembled the plane, or what, as the forums reflect a number of people who have flown them successfully.
Old 03-05-2014, 04:12 PM
  #181
evan-RCU
evan-RCU's Avatar
So did Dale think it was incidence or something or just didn't have enough time to figure it out? This is Henry, right?
Old 03-05-2014, 05:27 PM
  #182
ultra6a
My Feedback: (27)
ultra6a's Avatar
Yes this is Henry. I only remember him saying it was a handful both times he flew it. It may have been the incidence given the CG was not the issue. Also read in this thread where people had issues related to the wheel pants not being perfectly straight. They are really large and will act as rudders if they are not straight.
Old 03-06-2014, 07:18 AM
  #183
ultra6a
My Feedback: (27)
ultra6a's Avatar
Is yours going to be electric or gas?
Old 03-06-2014, 06:44 PM
  #184
evan-RCU
evan-RCU's Avatar
Electric, I have the set up sitting around and had been looking for a simple good looking plane like a old timer or WWI plane when I saw this. Not sure I should have got it now...
Old 03-06-2014, 07:49 PM
  #185
ultra6a
My Feedback: (27)
ultra6a's Avatar
Don't let me experience deter you. It is a beautiful airplane and I'm sure your building skills will address any issues with the plane.
There are a number of videos on You Tube of people who have had success with theirs.
Old 03-08-2014, 06:03 PM
  #186
evan-RCU
evan-RCU's Avatar
Well it got to me quick. A look while unboxing found cracks in every piece of fiberglass. The landing gear is very odd, the wires all corroded and loose in the pants. Canopy very warped. I sent a quick email about the cracked fiberglass immediately and haven't heard back yet, hasn't been long though, just yesterday afternoon.
After flying today I started the build by hinging the stabs with larger hinge points. Cut the covering for the stabs and wing mounting on the fuse and went over the covering. Mounted the stabs and wings to look the incidence and overall straightness out. The wings are okay but the mounting to the fuse on one side is horrible with a large gap above the wing. One aileron will need to have a twist removed. The biggest issue though is the stab is not flat to the wing. Not sure if I can twist the fuse enough to get it straight.
looks like I'll throw it together and if it flys spend some time to fix the many flaws. Good thing it wasn't expensive...
Old 03-08-2014, 07:05 PM
  #187
ultra6a
My Feedback: (27)
ultra6a's Avatar
Sorry to hear about all the issues with the plane. Is this the GMP or Hobby King version?
Old 03-08-2014, 07:18 PM
  #188
evan-RCU
evan-RCU's Avatar
They are the same plane. I got mine through GMP.
Old 03-08-2014, 08:32 PM
  #189
hornetnz
Other than the wraped canopy, I hadnt noticed any of those issues. Tho I will try to remember to check the level of the stab to wings. I'm guessing Gerry will do what he can for you.
BTW the gear wire IS loose in the pants. Once you mount the gear to the wing, and then mount the pants to the wing...the LG wire will float inside. This is one of the major flaws with this plane. Most ahve upgraded to Oleo struts, or used the flying wires attached to the wire instead of the wheelpants.
Old 03-09-2014, 04:24 AM
  #190
evan-RCU
evan-RCU's Avatar
At this point I'm not asking for anything other than a cowl and if I get one great, if not okay as I don't see this as a good plane. The wire needs to be fixed, attached to the pants...
Old 03-09-2014, 01:41 PM
  #191
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Evan,
I try not to work the whole weekend.... This weekend being my birthday, BUT I came down with the flu! The hatch's have ALWAYS been that way... Don't know why, But this summer let it sit out at the flying field with the hatch screwed down and it will come out. Where is it cracked at? The landing gear is made that way, loose fitting... We have tried to develop new ones. We have lots of oleo struts on order, been on order sense Oct. last year. Don't know, why the holdup. Where are they cracked at?
What happened to the Cowl? where is it cracked? Your plane was insured, so if we need to do something we will !!! There is a BIG hole on top of where the wing goes into fuse????? PLEASE send me pictures of all this and cracks in every piece of fiberglass..... My goal is not to sell JUNK to anyone, but sell a airplane at a affordable price!
Gerry
Also.... Sorry you don't see this as a good plane.........................
Old 03-09-2014, 05:07 PM
  #192
evan-RCU
evan-RCU's Avatar
Gerry, interesting you posted here instead of answering my email... Every flaw noted is not your fault. As I said in my email the plane had no box damage. I'm sure the warps and cracked fiberglass parts were nothing you had any control of. The cowl had its foam intact and in the plastic bag. Same with the way the fuse build has a gap (not a crack) between the wing and fuse. None of these things are things that could reasonably be claimed on insurance. As I said it would be nice to get a new cowl as this is the most notable damage. But I understand if they aren't available. I just ask that if you say you'll do something please follow through, too many vendors say they do something in a forum and never follow through. I'd happily talk off forum via email.
Evan
Old 03-09-2014, 06:29 PM
  #193
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Evan... Not at work computer
Sorry
Old 03-15-2014, 01:04 PM
  #194
hornetnz
Progress update...
I've got the cowl cut, pull-pull crimped and tightened, fuji water bottle tank with PSP parts installed, throttle servo mounted, control horns painted red, and working on a hidden compartment with door for my switches.
I had to move the ignition from the side where the previous picture shown, to the bottom of the engine box. It was hitting the cowl.
Also, you can see I've got 3/4" from cowl to spinner backplate. Wish it could be less, but shorter standoffs would put the carb inside the engine box.
Can anyone advise on the muffler cutout with regards to cooling? With such a big mouth on the front, I'm thinking this should be baffled. Should I have a bigger air exit hole?
Name:	2014-03-13 22.17.14.jpg
ID:	1978263   Click image for larger version
Name:	2014-03-13 22.17.23.jpg
ID:	1978264   Click image for larger version
Name:	2014-03-13 22.18.02.jpg
ID:	1978265   Click image for larger version
Name:	2014-03-13 22.18.16.jpg
ID:	1978266   Click image for larger version
Name:	2014-03-13 22.18.46.jpg
ID:	1978267   Click image for larger version
Name:	2014-03-13 22.19.06.jpg
ID:	1978268   Click image for larger version
Name:	2014-03-15 16.56.01.jpg
Old 03-19-2014, 04:32 PM
  #195
evan-RCU
evan-RCU's Avatar
Looking good. I've been away from home so building on mine has been minimal. Mounted the motor and soldered up my ESC connections and laid out where everything will go. I haven't heard a peep from Gerry so no news there. His only contact has been his posts above.
Old 03-21-2014, 06:02 AM
  #196
evan-RCU
evan-RCU's Avatar
Gerry emailed me! What he asked surprises me since I posted the damage above and he answered after my post... On the flip side while away working this week my Freewing Stinger 90 and A6E were delivered. No damage to either one and guess what will be move off my bench so I can build these first?
Hey Evan,
Sorry for the long delay!
Was the box damaged at all??? I really thought it was packed pretty good. Any signs of foot prints, holes, or anything else?
Again... Sorry for the Delay
Old 03-29-2014, 04:21 AM
  #197
evan-RCU
evan-RCU's Avatar
A couple emails and over a week later and nothing back from Gerry. Progress is moving on the build. I'm at the scratching my head to figure out what to do with the landing gear step. Other than this and the flying wires which go hand in hand and mounting the cowl she's done...
Old 03-29-2014, 05:33 AM
  #198
hornetnz
Lets see some pics!
Old 03-29-2014, 09:15 AM
  #199
evan-RCU
evan-RCU's Avatar
Gear is about done. I put in a u block against the pants and bolted the cable bracket, pant wood block and landing gear together with 4-40 bolts and then some big globs of epoxy/ microbaloons along the landing gear/ and pants inside along with a couple screw between the pants and wing have a pretty strong gear... Only issue is I didn't get enough of the little aluminium brackets for the cables. I got enough cables, swedges, turnbuckles and quik links though... I need 8 more brackets, looking at the angle they need to be though, about 90 deg, it's better to make some out of steel.
I need to make the cables between the top of the wings/ fuse and inside of gear/ fuse, swap out the nylon wing bolts for SAE steel wing bolts and blind nuts I have, mount the canopy and balance... not bad... Its about 14.3lb with batteries ready to fly.
I did get a PM from Gerry, just saw it from 3/9 saying he was sending a new cowl.
Here are some pics for you...
ID:	1982549   Click image for larger version
ID:	1982550   Click image for larger version
Old 03-31-2014, 05:59 PM
  #200
hornetnz
Nice work. Can you get any pics inside the wingpants? Im not sure I understand what you said you did.
Glad Gerry got back to you on the cowl!
