Edge 60/90 >
Edge 60/90
Edge 60/90
Old 09-04-2003 | 12:38 PM
Default Edge 60/90
Hi!
I'm searching for an ARF Edge in 60/90 size. I'm planning to use a YS 110 FZ engine in it.
The only model I have found so far is from Aeroworks. After reading the threads about it, I have decided to look for something else (it is a bit heavy, and too expensive).
Does anybody know of any alternatives?
Old 09-04-2003 | 01:02 PM
SunShyne's Avatar
My Feedback: (68)
Default Edge 60/90
www.VectorFlight.com
www.Extremeflightrc.com
you cant go wrong with either one. There are plenty of posts if you do a search for the VectorFlight Edge. nice plane!
matt
Old 09-04-2003 | 03:05 PM
birdie_in_texas's Avatar
Default Edge 60/90
lanier has a 1.20 sized plane also..
Old 09-04-2003 | 07:34 PM
Default Edge 60/90
Pacific Aeromodeling.
Old 09-04-2003 | 08:18 PM
Default Vector Flight Edge 540
Not a better one around! Check it out..... www.vectorflight.com
http://strato.net/~cooter/
Old 09-04-2003 | 10:10 PM
Burrito Bandito's Avatar
Default Edge 60/90
Natrajk,
I have to say that the VectorFlight experience has been great so far. I ordered mine (Edge 540 66") yesterday and talked with them alot via email before deciding to buy. They answer email questions very quickly and are very responsive.
Cootertwo who posted in this thread has a website with a ton of pics of his Edge. Everything I have heard and read about the planes is good so far. Take a look and good luck.
John
Old 09-04-2003 | 11:56 PM
Default Edge 60/90
Check out the Seagull Edge. At only $175, it's the steal of the bunch...
Old 09-05-2003 | 12:04 AM
My Feedback: (24)
Default edge
Get a yellow aircraft edge. www.yellowaircraft.com I have the 60 size and it is awesome. came in at 7# 3oz. with a .91 fx unlimited vertical. will fly like a pattern plane on low rates and will 3-d on high. you will love this plane I promise,
Steve
Old 09-05-2003 | 10:05 AM
Default Edge 60/90
Thanks for all the replies!
Which of these models perform 3d well?
Ps! Thanks for the great pictures Cootertwo and f2racer.
Your planes look great!
I also like the model from Yellow Aicraft except that the color schema is a bit to complicated for my taste ( would be ruined after repairs)
Old 09-05-2003 | 12:20 PM
Default Edge 60/90
I personally haven't 3D-ed my Seagull Edge yet. It came out to about 7 and 1/2 lbs with an MVVS 91 up front and flies pretty smooth. It also flies reasonably slow compared to other 60/90 sized aerobats that I've seen flying at my club. It's got generous sized control surfaces out back (but the ailerons are surprisingly small). I've only got 10 flights on it to date, and the elevator seems pretty sensitive and it will snap on full elevator defection even on low rates. I'm still getting comfortable with the model. I've got the battery currently in the stock location, so the plane may be a hair nose heavy, I plan on moving battery back in the fuse to see if I can cure the sensitive elevator syndrome before I try anything real wild. There's another thread where folks say that the Seagull 3D's pretty well.
BTW, I'm a reasonably proficient and have several Morris profile planes in my hanger, but I'm beginning to think that 3D-ing a more scale model (this "smaller" size at least, I've also heard that larger scale aerobats are easier to 3D) is a pretty different animal...
Old 09-06-2003 | 08:55 PM
Guest
My Feedback: (12)
Default Edge 60/90
I would personally look at getting one of the Vector Flight models. I have heard good things about the planes and the excellent cusotmer service from the company.
http://www.vectorflight.com/
Old 09-08-2003 | 09:59 AM
Default RE: Edge 60/90
we love our seagull edge it's a fine flier and so far can do most of the 3d manuvers well , we were a little nervous at first but she came trough with flying colors. at the price this is a good plane. follow the other threads for the tips and go for it[img][/img][img][/img]
ID:	59949   Click image for larger version
