SIG Kadet LT40 ARF - Pushrod question >
Old 04-29-2002 | 01:34 PM
Default SIG Kadet LT40 ARF - Pushrod question
I'm just about finished building my 1st ARF. One problem I'm having is with the rudder pushrod. I center my servo and hook up my pushrod. The servo can move the rudder from left to right just fine, but when I let go of the stick it buzzes a little. I believe the pushrod is binding or is to tight when coming out of the fuselage. I have spent hours and hours trying to fix the binding. Any advice? Should I replace the original pushrods with something else?
Old 04-29-2002 | 05:50 PM
My Feedback: (22)
Prock,
I just completed that step last night, and did find several problems with the directions for the LT-40. On the exit port for the rudder, it bends down into the airframe. The directions say to use a 7 inch threaded rod. The problem with that is the rod makes it bind at the entry point into the fuselage. I cut the rod down to 5 inches so that at even in full left rudder the rod is just aft of the entry point. Doing this kept the rigidity, but made the rudder not bind. I also found the "cutting lengths" for the push rods at the servo's to be long as well. Hope this helps. PM if you have any other questions. I will be glad to help if I can.
FW
Old 04-29-2002 | 06:33 PM
My Feedback: (8)
I had the same problem last year. I called SIG and they offered to make good by replacing the fuse (and all of the parts I had glued to it). Only problem was this was at the end of September and the fuse was on backorder. I wanted to fly ASAP so I decided to fix it myself. I considered replacing the whole rudder pushrod assy. Gave up on that when I saw I would have to make a hole in the plane to do it.
Then I dragged the fuse into the LHS where I bought it. The solution we came up with was Sullivan Gold N Rods. I picked a size small enough to fit in the existing tube in the fuse. To make it like the instructions, also picked up some threaded rod and DuBro 2MM clevises.
I think I still have the package. E-mail if you would like me to get the exact part number.
Old 04-29-2002 | 10:25 PM
My Feedback: (8)
Found the package, unfortunately the little cardboard tag is missing.
Just dug thru the Sullivan web. Product is S504 48" gold n rod.
I only used the inner piece. The guys at the LHS set me up with
2mm threaded rods same length as the LT40 arf provides. I guess the 2-56 rods would not go in to the sullivan tube. Bought a pair of DuBro 2MM locking clevis (#819)
I used this piece exactly like the LT40 directions said. Cut the wires to the same length
I replaced all the other clevis' with the DuBro lockers as well.
Good luck
Jim
Old 04-30-2002 | 12:33 PM
My Feedback: (22)
The Du-Bro rods work fine in the existing set up and you can use 2-56 rods.
FW
