 GP Lancair >
GP Lancair
GP Lancair
Old 02-23-2004 | 11:25 AM
Yuruki Karasawa's Avatar
Default GP Lancair
I am having problems landing our GP Lancair, yes it does come in fast but thats not it. when we put flaps down the plane wants to climb, now to me if the flaps go down then the plane will want to go down well i would like some help pleasssse
thanks
Old 02-23-2004 | 11:30 AM
tIANci's Avatar
Default RE: GP Lancair
I believe that when flaps are down the plane will want to climb a bit ... not too much but a bit for planes like the Lancair. Only on 3D planes where the wing chord is wide you have the plane diving as you use flapperones ...
Old 02-23-2004 | 11:45 AM
Slow it down quite a bit on final. Flaps give you lift when speeding up, it wont climb if you slow it down. Lots of times I dont even use the flaps.
Old 02-23-2004 | 11:47 AM
Alexdu's Avatar
If the plane wants to climb when you add flaps then I can think of two things: either you are lowering the flaps with too much speed or the c/g is not right. When I lower my flaps the plane doesn't even notice it. I usually lower them at midway between half and 1/4 throttle. I have a 91 Surpass on it. As you gain more confidence with the plane you will notice that you don't need flaps to land. Slow flybys are what the flaps are for.......
Robert
Old 02-23-2004 | 12:22 PM
well all of that is very helpful and the cord makes alot of since now, all of you thanks
Old 02-23-2004 | 12:51 PM
It has been hard for me to convince the trainees I help, to start slowing down during the downwind leg and let the plane have the proper sink rate using the throttle. When a pilot starts slowing after final turn and often too high, it's too late to bleed off speed. After the pilot moves to the low wing models and keeps the same habits, they wonder why the plane won't slow down.
Using the flaps and if for some reason have to abort landing, you have to be careful of sudden throttle up causing the plane to dive a bit. This can be expensive if you're too low and missed the runway and panic to make another pass.
Old 02-23-2004 | 02:58 PM
mimoore67's Avatar
My Feedback: (51)
Also, holding a little up elevator, will also slow the plane down. If you start to get to slow, then gentle lower the nose.
