 Phoenix SU-31 engine mounting. >
Old 10-07-2004 | 10:52 PM
My Feedback: (8)
Default Phoenix SU-31 engine mounting.
What do you think would work better when mounting a Saito 100 on this beefy bird? At 45 degrees, or completely inverted? I have the engine mounted at 45 degrees right now, but before I start cutting the cowl I am wondering if there might be a better way.
Old 10-07-2004 | 11:45 PM
tIANci's Avatar
Default RE: Phoenix SU-31 engine mounting.
I think 45 degrees down is nice so the exhaust exits below, looks clean ...
Old 10-08-2004 | 11:19 AM
p39
A Saito100? ... in this plane? It won't fly--- it will just rocket around. you could leave the wings off....
With the smaller wing- you better watch the landing speed. It sure won't float in.
Old 10-08-2004 | 12:39 PM
ptgarcia's Avatar
My Feedback: (36)
I flew mine with a Saito 72 and it landed pretty easily. The 100 is only 3-4 oz heavier. I don't think it will be much of a problem. And I would leave it mounted at 45 degrees so the exhaust exits directly under the plane. Good luck!
Old 10-08-2004 | 12:47 PM
ptgarcia's Avatar
My Feedback: (36)
By the way, I have parts for the Sukhoi available to anyone who needs them:
1. Wing - a little damage but not much. Nice aluminum control horns used also.
2. Landing gear - wheels and aluminum gear.
3. Wheel pants - cut out but never installed. I did spill a little CA on them, however.
4. Cowl - cut for Saito 72 at 45 degree mount.
If anyone needs some of this stuff let me know. You can have it...just pay for shipping. I can take pictures to show you guys also. See ya!
