 replace CA hinges >
replace CA hinges
replace CA hinges
Old 04-21-2005 | 04:46 PM
strulag's Avatar
My Feedback: (-1)
Default replace CA hinges
How do I replace CA hinges? I just cut the hinge to take the rudder off. What should I do to replace them? Do I need to somehow take the old ones out or do I have to make new slots. Do I need any special tools or can I get away with just an Exacto Knife. I'm fixing a crash. This is that last thing I have to do. Any help would be appreciated. Thx.
Old 04-21-2005 | 04:51 PM
exeter_acres's Avatar
Default RE: replace CA hinges
Just leave the old ones and make slots next to where the old ones were..... and you wil be just fine
Old 04-21-2005 | 05:25 PM
strulag's Avatar
My Feedback: (-1)
How do I make the slots (just with exacto knife)? How deep?
Sorry If I'm asking dumb questions but I've never done this before.
Old 04-21-2005 | 05:33 PM
Yes use an x-acto knife. Measure half of the CA hinge and that how deep the slot should be.
Old 04-21-2005 | 09:45 PM
Sturtz's Avatar
My Feedback: (20)
It's not a dumb question at all. In fact ,, it's smart to ask before you go tearing into something you've never done before.[sm=thumbup.gif]
Old 04-22-2005 | 06:14 AM
MinnFlyer's Avatar
If you've never done it before, read this:
http://www.rcuniverse.com/magazine/a...TOKEN=23572438
Old 04-22-2005 | 10:09 AM
Trogdor the Burninator's Avatar
That is a great article that I've seen before.. although I didn't follow the remove the covering around the hinge advice on one plane although I did drill the hole... seemed fine but later (after a crash unrelated to elevator) I was able to pull the hinges right out easily... CA hadn't wicked to the back deep inside, it was clean and doing nothing!
Old 04-24-2005 | 09:35 AM
gjeffers's Avatar
ive done that a few times with success,all i did was clean out the old ca hinge witha a exacto by sliding the blade down on each side of each ca hinge a few times carfully and work it back and forth and they will come out pretty clean.
Good luck
