help kyosho cap 232 elevator >
Old 12-15-2002 | 09:48 PM
Default help kyosho cap 232 elevator
Need help on elevator system for my Cap:
Grazie mille.
Old 12-15-2002 | 10:28 PM
My Feedback: (13)
Default .
hi carletto, ya need to be a bit more specific if you can. lots of folks would be glad to answer any questions ya have..
Old 12-16-2002 | 05:59 PM
Thanks Tinman, i have more trouble with the balsa bar and the adj rod.
Old 12-17-2002 | 10:51 AM
Carletto,
On mine I have kept the balsa push rod and the 2mm Y push rod. I didn’t use the heat shrink, but instead bound he push rods with twine and then soaked the whole thing in CA. This has proved to give a very stiff Y connection. I did the same at the other end to the servo. I didn’t use the 90 degree bends to the servo arm replacing it with a clevis. I think that the 90 degree bend stuff in control links are weakening the push rod and can introduce slop.
Good luck
Kris
