 Any Shoestrings out there? >
Old 09-05-2006 | 10:19 PM
  #51
BULL-RCU's Avatar
My Feedback: (15)
Default RE: Any SHoestrings out there?
ORIGINAL: chris8105
I am using a OS 91FX engine, and a bisson exhaust, and I have the battery(1600mah 4.8v nimh) as far in the as I can reach, and to get it balanced I need 3 ounces of weight on the tail. Does that seem like a little to much?
I cut open the monocoat of mine in the rear and placed a 2200 nimh in mine. I had to place it way in the back. I know a patch sucks but didn't want to add weight. your weight sounds about right.
Old 09-06-2006 | 08:36 PM
  #52
Primodus's Avatar
My Feedback: (56)
I am considering taking the OS91 Surpass II (pump) out of my chipmunk for this plane. Think that would make it sail?
Old 09-06-2006 | 10:08 PM
  #53
BULL-RCU's Avatar
My Feedback: (15)
ORIGINAL: Primodus
If I were you I would try and fine an OS 91 2 stroke. You will get much more speed.
Old 09-06-2006 | 10:25 PM
  #54
My Feedback: (22)
Hopefully I can get it in the air tomorrow. Run a couple tanks through it on the ground and then get it airborn.
Old 09-06-2006 | 10:31 PM
  #55
BULL-RCU's Avatar
My Feedback: (15)
ORIGINAL: chris8105
Wait till you fly this plane... This plane looks so great doing a low knife edge. I can carry a knife edge forever and straight as an arrow...
Old 09-09-2006 | 11:08 PM
  #56
Primodus's Avatar
My Feedback: (56)
Got the Maiden in on the Shoe with the Saito FA-80 in it. I was skeptical that it would fly at all, but it did. It actually had a little speed to it to boot. However, I can plainly see that I will have to update eventually. The handling is superb. Rolls are blazing fast. It will do a full pull loop without a hint of snapping out and keep right on chugging. Landings are fasst like I rememebr them, but that's not a big deal since I have a 2200' x 80' runway to play on. If I can't land it on that, I need to take up another hobby. Mine carries itself on 3.25" wheels under the pants and handles very well on grass. The previous owner beefed up the gear area nicely and it shows. The grass was pretty high. I look forward to stretching this one out for years to come.
Old 09-09-2006 | 11:15 PM
  #57
Cyclic Hardover's Avatar
ORIGINAL: Primodus
No t sure if your aware of this but I use Kavan wheels on everything I have. They have save my planes from quite a bit of damage. They are made of hard plastic. What this does is if you come in to fast and have to commit--or abort a takeoff. You can slide the plane sideways with no wheel hopping like its on ice. You do this with sullivan or skylight and your going to rip out the gear and or other major damage.
Old 09-10-2006 | 06:41 AM
  #58
Primodus's Avatar
My Feedback: (56)
ORIGINAL: Cyclic Hardover
Not sure if your aware of this but I use Kavan wheels on everything I have. They have save my planes from quite a bit of damage. They are made of hard plastic. What this does is if you come in to fast and have to commit--or abort a takeoff. You can slide the plane sideways with no wheel hopping like its on ice. You do this with sullivan or skylight and your going to rip out the gear and or other major damage.
Does that work on pavement or grass?
Old 09-11-2006 | 09:01 AM
  #59
tIANci's Avatar
Anyone got any comments about a Shoestring with a YS110 turning maybe a 12x10 prop?
Old 09-11-2006 | 09:22 AM
  #60
Primodus's Avatar
My Feedback: (56)
ORIGINAL: tIANci
Yeah, I have a comment...How fast does it go?! [X(]
Old 09-11-2006 | 10:57 AM
  #61
BULL-RCU's Avatar
My Feedback: (15)
ORIGINAL: tIANci
It would be a great combo... THe YS is the one four stroke that loves to be turned up... The ys screeming when the prop goes subsonic has a great sound...
Old 09-11-2006 | 12:26 PM
  #62
ORIGINAL: Primodus
both
Old 09-11-2006 | 03:19 PM
  #63
My Feedback: (22)
Anybody have any problems with the 91fx and the bisson pitts muffler? I took it down to the field today and it acted like there wasnt enough back pressure from the exhaust to the tank. Turning the high end needle did nothing.
Old 09-11-2006 | 03:22 PM
  #64
Primodus's Avatar
My Feedback: (56)
Exhaust leak? (guessing)
Old 09-11-2006 | 04:58 PM
  #65
BULL-RCU's Avatar
My Feedback: (15)
ORIGINAL: chris8105
That is the same set up I have run for the last 2 years and just started to have that problem with mine. I haven't had a chance to check it out yet... I figured I had an exaust leak or fuel line leak... Any how acted like I was getting air from somewhere. No matter how much I turned the high it didn't seem to change.
Old 09-11-2006 | 05:09 PM
  #66
My Feedback: (18)
yesterday mine started leaning on me with my 61FX, and on one low pass the engine went from max RPM to dead, no hesitation.
I had enough speed to do a big banked turn (I love this plane's stall characteristics) and get turned upwind and glide althe way to the far end of the runway before rolling into the tall grass. Upon inspection, my Slimline F1 fueler cap had fallen out. That was the least of my worries though because I could see that everything inside the cowl was coated with fuel and oil.
Turns out that my fuel tank stopper had worked loose - I initially thought I had a leak in my tank right at the neck - cause when I filled the tank fuel would pour out the hole int he firewall.
Am I the only one that noticed that the stock fuel tank doesn't seem to really fit between the firewall and the F1 former without a lot of muscle involved?
Also - mine, and a buddies both had issues with the 2nd and 3rd formers in the fuse coming ungled from the sides of the plane - a little epoxy and tri-stock is a quick cure.
Old 09-11-2006 | 10:42 PM
  #67
Sandyt's Avatar
Pretty funny. I just responded to this same question that you posted on a different thread. I didn't realize we were talking about the same plane!
http://www.rcuniverse.com/forum/fb.asp?m=4738136
Sandy T
Old 09-14-2006 | 04:49 PM
  #68
My Feedback: (22)
What color monokote is the shoestring, is it yellow or cub yellow?
Old 09-14-2006 | 05:21 PM
  #69
My Feedback: (18)
cub yellow
Old 09-15-2006 | 04:12 AM
  #70
tIANci's Avatar
I love the looks of the Shoestring, its so nice and I have a YS110 sitting in the hobby room. With a 14x10 I should be getting about 9,750 RPM only. Still would be really interesting. I think I have a 12x12 prop somewhere in the bag. Hmmmm ... I would estimate the top speed to be about only 90 mph. Not ballistic but then with a 14x10 she will really have good thrust.
Old 09-15-2006 | 09:45 PM
  #71
Primodus's Avatar
My Feedback: (56)
Upgraded the powerplant this evening.
Before = Saito FA-80 on a 13x6MA
After = OS 91FS Surpass II w/pump on a 13x11APC
Think it will go faster? [sm=48_48.gif]
Old 09-18-2006 | 03:30 PM
  #72
My Feedback: (18)
We clocked one on a handheld radar gun with a Saito 100 and a 13x10 K-series - was somewhere in the 110-114 range if I remember correctly. We're only 70 feet above seal level here - engines make a good bit of power.
Old 09-18-2006 | 05:38 PM
  #73
Primodus's Avatar
My Feedback: (56)
I changed to a 15x7APC and she stretches out nicely. I still think if you want this bird to reach her full potential, you'll need a good 2 stroke.
Old 03-06-2007 | 07:05 PM
  #74
My Feedback: (22)
When you guys change the color scheme of your planes, do you paint the cowls and wheel pants or cover them? How long does a job like that take, covering a shoestring.
Old 03-06-2007 | 08:32 PM
  #75
Iflyglow's Avatar
My Feedback: (79)
You would have to paint the cowl and wheel pants. If you are the one who posted about covering the belly in another forum, you do not want to tackle the whole plane.[X(]
