Reload this Page >
Hangar-9 Sopwith Camel Build Thread
Old 10-28-2014, 07:09 AM
  #1351
ToolJoint
Great summer of flying...The weather here has been quite nice as well and we have been out to enjoy it a few times. Here's a shot of my Camel with his stable-mate which I got in January, The Great Planes P6E (original with Saito 150, not the new 'castrated' electric version). The Hawk lands similar to the Camel, but is WAY easier to fly all around. I'm glad I learned about bi-planes with the Camel. I think it's kind of like learning to ride a dirt bike before your kiddie bike...ha.
Old 02-21-2015, 03:31 PM
  #1352
aerowoof
subscribed
Old 02-21-2015, 07:54 PM
  #1353
hairy46
Welcome,
Old 02-22-2015, 04:03 AM
  #1354
Mustang Fever
Mustang Fever's Avatar
I
Always suspected that the wing panels on the H9 Camel were twisted, and not anywhere near equal incidence left to right. Got real bored this winter, put the Camel together, and hauled out my helicopter digital pitch gauge, which makes a great incidence measuring device. Results: right hand panels both hand more incidence than the left ones. That's why this bird has always fought right turns, and needed almost half an inch of right aileron trim to fly in a straight line.
You know those little fiberglass adapters that come with APC electric props? I used a bunch of them to shim the panels, putting them between the panel and the ends of the cabane and inter wing struts. Everything is pretty close to identical, now, with a little bit more incidence on the left panels, which is what this thing needs with all the torque from that G60 motor and the 17" prop.
The pictures show it better than I can describe it
Anyway, she'll get tested this spring. I've become so fed up with the squirrelyness of this aircraft that if this doesn't correct it, it'll be going up for sale, and I'll build a BUSA Spad XIII. I have a BUSA DR-1, and it flies 10 times better than the Camel.
Name:	RH Aft Inter.JPG
ID:	2075338   Click image for larger version
Name:	RH Aft Cabane.JPG
ID:	2075340   Click image for larger version
Name:	LH Forward Cabane.JPG
ID:	2075341   Click image for larger version
Name:	Top Bottom LH Fwd Inter.JPG
Old 02-22-2015, 05:15 AM
  #1355
Azzir325
That's interesting, Fever. I always figured my wing panels were not straight simply because of their nature, and the fact that most landings ended in noseovers, however, squirrelyness was never an issue. Mine flew true and authentic to the genre, ie: loves rudder in the turns. I used the lead block included with the kit, and a Higley heavy hub on the maiden. When I took the heavy hub off, it DID make a difference. I almost maidened her without the lead because it hung nearly level on my balance beams. When I put the one pound lead block on the nose, the plane moved less the one half inch (!!!!!). If I had flown it without the lead, it would have been a disaster! In my experience, squirrelyness translates to tail heavyness, and with this plane in particular it is true. I put the heavy hub back on and never took it off. If your plane doesn't hang dead level or slightly nose down on the balancer, it is tail heavy and will always be a squirrel. As for the noseovers, H9 chose a scale landing gear (read that "narrow"), whereas BUSA (I LOVE BUSA, BTW) models generally sport a wider stance gear which helps their ground handling. I moved the block of lead to a position under my motor, and that helped, but it is still tough to land.
BTW, I have a snoopy pilot too.
Name:	Sopwith flyby.JPG
Old 05-30-2015, 08:38 PM
  #1356
WI53072
Picked one of these up from a fellow area flyer. Begining to fit it with a eflite power 52. Should fly well on 5 or 6 s.
Old 05-31-2015, 07:41 AM
  #1357
aerowoof
I was going to do the same but was undecided between the recommended eflite 46 or going with an eflite 60.would like to see how the 52 works out for you, keep posting please
Old 05-31-2015, 08:30 AM
  #1358
WI53072
Right now I am working on moving the elevator and rudder servos as far forward as I can. The power 52 flew my H9 RV8 really well on 5s.
Old 06-01-2015, 12:25 PM
  #1359
tclaridge
tclaridge's Avatar
On 5S the Camel will fly well. I fly a 4S with a Power 46 and it is scale. Can do a loop from level.
Old 07-25-2015, 11:44 AM
  #1360
plopes
Hi Guys, I have just completed my camel build after a few years of it sitting in the box...
It has a thunder Tiger .91FS four stroke with home made on-board glow.
Sprayed the shiny covering with Tamiya PS-55 with gave it the perfect look.
replaced the machine guns with Williams bros guns.
Added extra rigging and fake fuel pressure slipstream pump.
Old 07-25-2015, 11:49 AM
  #1361
plopes
ID:	2111092   Click image for larger version
Old 07-25-2015, 11:52 AM
  #1362
plopes
ID:	2111094   Click image for larger version
Old 07-25-2015, 11:59 AM
  #1363
plopes
ID:	2111097   Click image for larger version
Old 07-25-2015, 12:22 PM
  #1364
hairy46
Looks great! Have you flown it yet?
Old 07-25-2015, 12:38 PM
  #1365
plopes
Thank you,
Nope, I have not flown it yet.
I am pretty apprehensive about getting this bird up to be honest, It just looks like a handful.
Old 07-25-2015, 01:23 PM
  #1366
Azzir325
Originally Posted by plopes
Thank you,
If you have the balance right, this plane flies like a ***** cat. Sometimes it is better to let an experienced friend make the first flight. He's not as invested as you are, thus his hands probably won't shake as badly! LOL!
Old 07-25-2015, 09:10 PM
  #1367
yellerchamp
My Feedback: (42)
yellerchamp's Avatar
I had one of these with a saito 91 in it, it flew okay but needs only small amount of elevator, just add power and it climbs also no glide ratio other than that pretty standard
Old 07-26-2015, 02:58 AM
  #1368
Azzir325
p u ss y cat!
Old 09-06-2015, 09:19 PM
  #1369
Jim Oliver
Trying to contact aerowoof; can someone help me out?
Jim Oliver
Old 09-29-2015, 11:06 AM
  #1370
tyor
tyor's Avatar
I have this plane with a saito FG19cc r3 gas. The engine is a perfect match for this plane. but I had to add 360gram (12.7oz) lead and still it is a little tail heavy. but flies great.
ID:	2122834   Click image for larger version
Old 11-01-2015, 09:03 AM
  #1371
tyor
tyor's Avatar
video of my camel with saito FG19cc
https://youtu.be/RY_pToj5IuE
Old 11-03-2015, 04:20 AM
  #1372
tclaridge
tclaridge's Avatar
tyor, thx for sharing the video. You make landing a Camel easy! It is too bad that Horizon is no longer carrying WWI aircraft like this. I think they are great, and I still fly mine (built in 2007). I recently updated the sound system, so here is a quick sample just to show you can get a little noise from an electric.
https://youtu.be/4e8a-a3DEuw
Old 11-03-2015, 07:12 AM
  #1373
spitfire1999
My Feedback: (21)
Hey Guys, well I just picked up a derelict Camel at an estate sale, but it's missing the top fuselage cockpit/hatch. It could also use a new cowl. Anyone have some parts they would like to sell?
Old 01-18-2016, 04:50 PM
  #1374
WW1 Flying Ace
WW1 Flying Ace's Avatar
I am assembling one of these, and have just about given up trying to get the wrinkles out of the covering. I think I'll strip it and re-do it in Koverall and dope. Is there enough reader interest out there in this old ARF for me to post pictures, etc?
Old 01-18-2016, 05:08 PM
  #1375
spitfire1999
My Feedback: (21)
Sure! Always love to see what people do, especially if your going to strip and recover! Now you will be able to get the proper colors with CDL on the bottom instead of gray and PC-10 on the top sides.
