 problem with Mini UltraStick ARF >
Old 10-11-2006 | 07:13 PM
Default problem with Mini UltraStick ARF
I just bought the Mini UltraStick ARF. It came with the motor, servos, and Speed controler. I bought the JR Sport negative shift receiver (RS6UL) and Parkzone's high performance Li-Po battery and charger combo (http://www.parkzone.com/Products/Def...ProdID=PKZ1050).
I installed everything, but I am struggling with a problem. When I plug the battery in all of the servos twitch and I can't control them at all. The throttle doesn't go at all. My LHS said I could bring it back for him to take a look at, but I thought I would run it past here first and see if I can't fix it before then.
Any and all advice is appreciated. Thank you in advance.
David
Old 10-11-2006 | 07:54 PM
Ed_Moorman's Avatar
Default RE: problem with Mini UltraStick ARF
What kind of transmitter? JRs are normally positive shift. Are you using Futaba or Hitech?
If your transmitter is one that will do both PPM & PCM, does it default to PCM? The JRs come set for PCM and you have to set the modulation to PPM.
Old 10-11-2006 | 08:04 PM
This is the transmitter I have (http://www.*********.org/jr-6102.htm).
Thank you for the reply. Does that help?
Old 10-11-2006 | 08:30 PM
w8ye's Avatar
My Feedback: (16)
That appears to be a positive shift transmitter?
The RS6UL receiver comes either negative or positive. Take it back and get a positive shift one
Old 10-11-2006 | 08:45 PM
Thanks for the posts I'll take it back to him tomorrow and try a positive shift receiver... thank you both for the helpful replies.
David
