Reload this Page >
CMP Cessna 182 Building Thread-->the best scale Cessna 1.20 size ARF that is on the market!!!
Old 10-26-2016, 05:23 AM
  #1251
FlyerInOKC
FlyerInOKC's Avatar
Check your attachments they are either an incorrect format or corrupted.
Old 10-26-2016, 12:20 PM
  #1252
HUNTERANDJEFF
Unbelievable,
I have tried to email the administrators several times and all I get are crickets. Is anyone still running RCU?
Do the 1st two and the last two posts show pics and videos?
The pictures I posted were all on the same jpeg format. Rc Universe is just not the same as it used to be.
J
Old 10-26-2016, 12:34 PM
  #1253
FlyerInOKC
FlyerInOKC's Avatar
Try altering the size slightly and then reposting. I think they are short one ADMIN so things are a little hectic.
Old 12-26-2016, 03:21 PM
  #1254
DragonLines
My Feedback: (13)
DragonLines's Avatar
Sorry for some reason not getting notified by RCU of anything. I picked up a set of Top Flight gear. I can make them work. Thanks
Old 01-20-2017, 07:05 AM
  #1255
1UGLYPUG
I took my old set to a machine shop and had some good stainless steel ones made. 70 bucks, but they don't bend or break anymore.
Old 01-20-2017, 07:39 AM
  #1256
NCRC
My Feedback: (32)
NCRC's Avatar
Do you have a picture?
Old 01-20-2017, 04:40 PM
  #1257
1UGLYPUG
Page 41, post 1017
Old 06-10-2018, 08:33 PM
  #1258
SkyDriller
Does anyone have the assembly instructions for the CM Pro Cessna 182 Skylane 140 (2100 mm span or 82.7"). Will appreciate a PDF or JPG
I have one that has been lying with me un-built for many years. Finally decided to build it but find the assembly instruction manual missing.
Planning on putting a DLE 20 RA on it - any comments? Also keen on knowing about modifications to rudder control - stock option doesn't look too good.
Old 06-11-2018, 03:52 AM
  #1259
DragonLines
My Feedback: (13)
I have a set I can scan but I am on a trip right now. May be a couple days.
Old 07-07-2018, 02:54 AM
  #1260
SkyDriller
Hi DragonLines - sure could use your help with the scanned copy of the CM Pro Cessna 182 Skylane 140. Will be a great help.
Thanks!
Old 07-07-2018, 03:34 AM
  #1261
DragonLines
My Feedback: (13)
Sorry, I forgot about it once I got home. I will scan it today and get it to you
Old 07-07-2018, 07:20 AM
  #1262
DragonLines
My Feedback: (13)
Have it ready to send but it is a pain on RCU send me a message with an email address and I will get it off to you
Old 07-08-2018, 10:37 PM
  #1263
SkyDriller
Thanks a lot DragonLines - I've PMed my email ID to you
Old 07-15-2018, 08:28 AM
  #1264
RBean
I have noticed that the nose gear strut on most seem to be mounted straight down. The nose gear of the 182 is actually mounted with about a 15 degree forward rake. My brother who was an engineer at Cessna said the forward rake reduced the rearward stress on the nose gear about 30-35 precent. I owned a 1976 182P for 15 years and put about 3,000 hours on it. On the full size the nose gear needed to be handled with care. I always tried to land on the main gear and hold off the nose gear until the plane slowed, setting the nose wheel gently on the ground. On take offs tried to hold back elevators at the beginning to keep weight off the nose gear during initial acceleration. Always taxied (weather permitting) with full back elevator to keep stress off the nose gear. Also the prop higher off ground to lessen picking up debris. Nose wheel locked straight when fully extended so some times had to tap the breaks to make turns. If the bushings got worn and shimmy dampener also worn, nose gear could develop a violent shimmy. When this happened the nose pant was often damaged. That is why you see a lot w/o nose pants. Only makes about 2kts difference.
182 was/is a great airplane. It could have been faster and used less fuel. Has STC for car gas. It would carry about all you could load in it, had a large cg range. Had 80 gallon tanks so a long range. Steady instrument platform. Had HSI, Storm Scope, and coupled auto pilot. As airplanes go it was fairly low maintenance. Still, when my situation changed and couldn't write off as business expense, couldn't afford and had no pressing need for it. Still miss it after 20 years. There is nothing like being able to go to the local airport and go where you want, when you want.
Old 09-01-2018, 07:53 PM
  #1265
lcruz
Default Need help need manual
I purchased this plane last year but I am missing the manual. If someone would be kind enough to scan it and email it to me I would be very grateful. Or if someone could point me somewhere where I may download it.
thanks much
Lionel
My email is [email protected]
Old 09-03-2018, 04:40 PM
  #1266
lcruz
Default Help with manual for CMP 182 1.20 Cessna
Hello rc brothers,
I purchased this CMP 1.20 Cessna and I am in need of the manual. Can anyone assist me.
-Lionel
Old 09-07-2018, 02:01 PM
  #1267
DragonLines
My Feedback: (13)
I have them in pdf form PM me an email address and I will send them to you
Old 09-09-2018, 08:02 PM
  #1268
lcruz
[email protected]
Old 09-10-2018, 07:03 AM
  #1269
lcruz
Thank you so much
[email protected]
Old 09-12-2018, 01:21 PM
  #1270
lcruz
my email is [email protected]
Old 10-31-2018, 01:36 PM
  #1271
DragonLines
My Feedback: (13)
Just now got a notice on this. I have sent the plans to your email
Old 11-25-2018, 06:10 AM
  #1272
DragonLines
My Feedback: (13)
Just a FYI for those still building the CMP I was flying mine yesterday and it was doing fine then it started to spin and headed for the ground. Best guess is the factory servo tray broke loose causing loss of control. You may want to add a little epoxy to the glue joints for safety. It was fun while it lasted.
Old 12-22-2019, 04:48 PM
  #1273
[email protected]
Default CMP Cessna 120 Wing Tube
Hello fellow modelers,
I am looking for some assistance with my CMP Cessna 120 size.
Could someone please tell me what are the dimensions of the wing tube. I am looking for the length and outside dimensions of the aluminum tube used to join the main wings. Also if you know where I could purchase it. I purchased this kit years ago and seem to have misplaced the wing joiner tube.
Thanks much
Lionel
Old 12-27-2019, 09:09 AM
  #1274
[email protected]
Default CMP Cessna success?
Wow guys,
I am reading some horror stories regarding this plane on this thread.
Is anyone out there still successfully flying this bird?
Old 01-02-2020, 02:12 PM
  #1275
darod07
My cessna already crashed. I was lucky owner for 6 years with hundreds of flights but finally sold plane to friend of mine. He stalled plane in very first flight...Problem was that he is experienced only with aerobatic planes. Cm pro Cessna is completely diffrent bird to fly...
