 Nitroplanes Pitts Special 40 >
Old 03-11-2007 | 01:32 AM
Default Nitroplanes Pitts Special 40
I just wanted to report on my Pitts Special. I flew it for the first time today. It took off with very little rudder correction and the only trim I had to do was a coulple of clicks down on the elevator. It handeled like a dream. I have a Supertiger 40 in it and has plenty of power no problem there. The mods I made to it was to put 4/40 blind mounting nuts in the wing tabs for easier assembly. I will say that you should run some CA down along the wing tabs for extra strength. The plane flys super good no bad habits and lands like a dream. The only thing that I thought needs improving is the landing gear it seems to bend on a hard landing. Just land nice and easy and you won't have any trouble. I hope this information helps. In my opinion it's a winner flys geat lands nice and smooth looks great.
Happy flying, Tailspincharley
Old 03-13-2007 | 01:19 PM
Default RE: Nitroplanes Pitts Special 40
Thanks for the info. I have yet to maiden mine. Plane is a little small for my 40 size skis. I have a saito 65 in mine and i am sure I will have unlimited vertical. I replaced the kit gear and installed a slightly wider set, stock ones seemed a little narrow for my tastes. One guy had the struts break, but mine seem strong as ever needed. Maybe a cartwheel would weaken them. When test running the engine I noticed the fuel tank bung plastic retainer split, I am sure I didn't over tighten it, but check yours, maybe poor material.
Old 03-13-2007 | 03:10 PM
opjose's Avatar
Did you do anything about the canted struts?
How did you mount your engines?
Thanks.
Old 03-14-2007 | 12:27 PM
I didn't do anything about the struts besides running some medium ca around the attachment points. I have had the plane assembled for about 2 months now and just pulled the wing off to check something and there wasn't much of a pull on the struts, they seemed to have taken shape to the bend somewhat. I am going to fly it like this, if I botch a landing I will check them over carefully. I mounted the saito horizontal, why hide a nice looking engine like that? Plus I have had nothing but problems with my superchipmunk with an inverted install, always having to close off the high speed needle when filling the tank.
Old 09-22-2007 | 11:45 PM
Looking for updated thoughts on this plane. I am thinking about picking one up. Would an OS 40 be enoupg power for it? Thanks.
Old 09-23-2007 | 05:29 AM
opjose's Avatar
An OS .40 FX or the like may be enough depending upon how you load the plane down with other hardware... e.g. bigger battery packs, etc.
Old 06-21-2009 | 08:09 AM
Hisham's Avatar
any more info about this plane,
any posted  videos
thanks
Hisham
