 Hanger 9 Tango >
Hanger 9 Tango
Hanger 9 Tango
Old 11-10-2007 | 07:22 PM
  #51
Default RE: Hanger 9 Tango
Maiden flight for the Tango today. ON low flew very nice and gentle but on high WOW .Have an OS .46 ax in it and it did what ever u wanted it to do. Less then ten foot loops and rolls so fast i could not count. This is the plane for this winter when the snow falls the skis will go on.
Old 11-11-2007 | 11:37 AM
  #52
lol, i crashed mine in the first flight. i need a fuse now. it was way to windy and i flied anyway. i had my low rates to low to fight the wind and was too dumb to switch to high rates. the tango and i fought for 10 minutes and i finally got it back to the landing strip and ....well the wind finally won!!..lol...this thing reall balloons in the wind!!
man that 55ax is a sweet engine though. i cant wait to fly it again.
how much expo are you guys running?
any on got a dx7 and want to post there programming fot the tango?
Old 11-11-2007 | 05:26 PM
  #53
I am running my expo 50% on low 60% on high. THis plane is everything from mild to wild. Loops less then ten feet in size. It is a blast to fly even though im a new pilot its making me look better then i am . I cant get enough of it. Put the hangar 9 mustang trainer away to go wild with this thing . Floats in for landings . Today the winds were 23 KMS an hour and did not bother it a bit.
Old 11-11-2007 | 05:32 PM
  #54
Everyone at the club is crazy about this plane and are lining up to get one for the winter. We think this plane will be great with skis on it. I let a few try it out and we all agree its mild to wild . Hangar 9 really did it with this one and easy as pie to put together in a couple of hours.
Old 11-11-2007 | 10:02 PM
  #55
I have a O.S. 46 AX for my Tango...what props work with this setup? Thanks..............
Should maiden this Wednesday.......
Old 11-12-2007 | 12:55 AM
  #56
I want one. Not sure why. [sm=confused.gif]
Old 11-12-2007 | 06:18 AM
  #57
Im using a 10/6 only for reason of breaking in my .46 ax but will be changing up to 11/7 this weekend.
Old 11-12-2007 | 09:10 AM
  #58
foresterxt's Avatar
My Feedback: (35)
ORIGINAL: flyman1948
I'd go with an APC 12x4.
Old 02-18-2008 | 01:43 AM
  #59
Update: It's been a few months since the last car repair, and it seems to be holding up OK. I happened by one of the local hobby shops, looking for a set of skis for my Slow Poke 10. And there it was, and this one I didn't have to back order. Now, this hobby shop is among the best I've seen for their customer service. Not only did I get my Tango, but I got the skis along with it, free of charge. What a deal! Needless to say, they earned themselves a permanent customer, even though I have to drive a few more miles to get there.
I plan to install my OS 55 AX, and use the JR SX-600 radio with ST47 servos for the ailerons, rudder, and elevator. I have an extra 527 given to me, and that will go for the throttle. If anybody knows how this will work, feel free to chime in. Also, how's the winter flying? I got a few good ones in with the Slow Poke last weekend.
NorfolkSouthern
Old 02-18-2008 | 04:10 AM
  #60
ORIGINAL: foresterxt
I put an Evo 52 with a 12x6 prop on it,just awesome,got to watch I don't use full throttle at take off or it trys to torque roll
Great to run aerobatics and 3 D
Can just waffle around the sky or blast around like a rocket.
So Happy with the Tango[8D]
Old 03-12-2008 | 11:15 AM
  #61
I flew my on Saturday with a Saito .72 on the front. Im still breaking the engine in, and am swinging a 13x7 prop, which is way too much prop. I was having the same problem someone else was, as mine was wanting to torque roll on takeoff at about 3/4 throttle. Im flying right now with about 50% expo, and I'll probably back that down to 35% or so. Mine will speed up or slow down as fast or as slow as I want.
Justin
Old 03-14-2008 | 10:26 PM
  #62
how much throttle did it take to hover the tango with the o.s. 55?
Old 03-15-2008 | 05:35 AM
  #63
With Evo 52 it takes 1/4 -1/3 depending on conditions to hang it from the prop
Just a fun thing to fly
Cheers[8D]
Old 03-15-2008 | 12:03 PM
  #64
what size prop are you using on your 52 evo? i'm running a 12.25x3.75 on my twist with an evo 45 spinnin it and it hangs around a half when tuned at peakpower.
Old 03-15-2008 | 10:11 PM
  #65
foresterxt's Avatar
My Feedback: (35)
ORIGINAL: friz
That's funny [sm=lol.gif] That's exactly what I thought when I saw one for the first time. I should have one of these, not sure why but I'm after I buy one I'll figure it out later.
Old 03-16-2008 | 05:11 PM
  #66
I went ahead and maidened mine earlier today. This thing is real squirelly at takeoff, so be sure to have both thumbs ready! Anyway, it windmilled in the cross wind and dropped a wing just about before it was ready to fly. I applied opposite aileron and gunned the throttle of my 55 AX with the APC (the ugliest prop ever invented) 12 x 4 and pointed it strait up. Otherwise, I would have had a "nose in the dirt" episode like I did the night before. IT went vertical, thank the Good Lord for a good engine! Ease the throttle and some down elevator, and we're level. It rolls on the center axis. It can roll with just rudder alone, in fact. It probably flys better inverted than it does right side up. It'll slow down almost like a Slow Poke, and just about hover in a head wind, but then you can speed up and cut right through it with no problem, and accelleration is quick. This is a touchy little critter, and 10' loops (both inside and outside) are second nature. Landing is what the plane seems to do best, just keep the wings level and steer with the rudder. Flair with some up elevator and it'll settle in for a 3-point. This thing takes some getting used to. It's definitely not a beginner's plane and it will bite if you're not ready, but that's just the beauty of it. I don't think I'll get bored with the Tango any time soon!
NorfolkSouthern
Old 03-16-2008 | 11:01 PM
  #67
ORIGINAL: procrasher
Using a 12x6 prop,works a treat for everything[8D]
Cheers
Old 03-17-2008 | 12:52 PM
  #68
The Toolman's Avatar
I told ya that plane is spooky........LOL But I luv it just for that reason.
On takeoff I get it headed straight down the runway then nail the throttle an yank it straight up in the sky. Works great everytime.... Now you see what I meant by saying it flys upside down as good or better than right side up.
Your right, we won't get bored with this little critter anytime soon
Ronnie
Old 03-17-2008 | 07:42 PM
  #69
Oh, by the way, I took the 65 la off of mine an stuck a new TT.46 pro on it I had laying around an it is MORE than enough engine for this plane. I'm using a 11x5 mas prop also. Excellent pullout power from this prop IMHO.
Ronnie
Old 03-18-2008 | 04:28 PM
  #70
Sure figured there would be more interest in this plane than 3 pages or so..... I guess some are afraid to try it out I suppose, because of it's radical behavior in the air........
Ronnie
Old 03-18-2008 | 05:40 PM
  #71
Ed_Moorman's Avatar
Check over in the 3D forum. There is a thread over there.
[link=http://www.rcuniverse.com/forum/m_6657749/tm.htm]Tango 3D Thread[/link]
