Top Flite B-25 ARF (Tecnical, tips, suggestions)
#2951
My Feedback: (20)
TX
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
I do not have the yoke posts and control yokes to put in place. Does anyone have what came with the kit they want to part with?
I found them hiding.
#2952
Does anyone have a spare used or new nose windscreen and chin set? (TOPA-1715). I dropped mine, broke it into pieces on the front.
I'll pay fair value, plus shipping cost to me! Thanks, J.B.
#2953
FL
ORIGINAL: JBoyd58
I think I do. Not positive. I'll be home in one week and I will look.
You can also check with Hobby Services. They are very nice a will send you parts from destroyed/damaged kits.
SR
#2954
JBoyd58,
Go to this site http://www3.towerhobbies.com/cgi-bin...?&I=LXTFT8&P=7 you can purchase the parts for $22.49 less shipping.
#2955
I should have mentioned, I've been all over the internet. And this part is on back order until late May.
Including Tower Hobbies. I was looking, to maybe get one sooner through a post here and there.
Thanks anyway!
Thanks anyway!
#2957
FL
ORIGINAL: normandouellette
I have that, watch me brake mine now.... pm me
Normand
Normand
SR
#2960
FL
I am going to satrt my build .... I purchased two os 95v for the plane . Has anyone used them in this plane yet? Will they be a good match for the B-25?
#2962
Hi guys hopefully someone can help.
I am going the cheaper all I can afford two stroke power route.
I made up the right hand power pod and there is a straight forward route to the trottle but on the left hand side the servo is on the opposite side to the trottle giving a very messy route to the carb.
Has this problem been solved here?
#2963
You should have the engine pods set up identical. The only difference in the two in thrust angles. Pictures would be very helpful.
#2966
Seamus OLeprosy,
Hi, I had gone the cheapest rout also when it came down to engine sellection. Currently I have two OS AX .46 2S engines with power box mufflers turning two APC 11X8 props. At full power my engines are turning at 10500 rpm which provides plenty of power to take off from my grass field. After take off and my first turn heading down wind, my gear has been retracted then flaps brought up, I can fly at 2/3rds to 1/2 throttle and stay airborn for ten minutes. After landing I have enough fuel for an additional two minutes of flight if I over shoot or need to go around for another landing attempt.
As for the throttle servo's, they are located on different sides of the nacelle, just try to rout them as strait as possible or if you can engineer a new servo mount which will short'n your servo arm run. Good luck with your build
#2967
Here is what I have
As you can see the right/top engine pod has the control rod attached in a nice straight line down the side of the tank to the carb.
But on the bottom/left power pod you will see the servo positions are on the oposite side to the carb and the tank gets in the way.
I was hoping someone might direct me to images of what othere have done to fix the problem
#2969
I just reread the manual and your gonna have to put in the lower position. There is an illustration for it along with a seperate servo mount to stick inside the motor box. Page eleven shows where to mount servo.
#2970
Thought of that but the ASP has a back needle adjuster and if you turn it 180 the nipple points forward.
Its only because its a twin and I want the trottles to be 100% reliable that concerns me.
#2971
I'll have a look in the morning thanks
ORIGINAL: rcnut101
#2972
I cant believe I'm the only one who had the two stroke throttle problem, anyway here is my solution, any way here is what I did.
Basically a hardwood dowel and a couple of belcranks. All symmetrically assembled so their is no mechanical advantage/disadvantage compared to the other side.
#2974
FL
ORIGINAL: Seamus OLeprosy
I think a lot of folks had the same problem, just different solutions. I just bent the wire around the tank and then turned the arm to face the direction of the trust. Works perfect. Another solution is "Dubro Golden rods". They work on the same principle.
In the photos the throttle settings are identical. The vector of force of are different at the servo but the same at the carb.
SR
#2975
Thanks Speedy, How's she flyin', what motor/prop combo, and did you
manage to get a replacement yellow dome nut for a two stroke?
