Engine for hangar9 edge 540 >
Old 10-02-2002 | 01:32 PM
Default Engine for hangar9 edge 540
OK. The Saito 180 is a GREAT engine, but Horizon doesn't have it right when they say to use a 16X8 prop. That is too small for that engine. No 4 stroke should go above 10,000 on the ground, regardless of what the instructions say. They will gain RPM in the air, and you will wear it out too fast. YS engines are the only exception. Some of the smaller ones are built to rev up higher. A 16X10 prop is better, but something like a 17X6 is good. The only problem is the 17X6 is hard to find, but I have seen them. I saw a Saito 180 on a Sig Extra and with the 16X10 it was a rocket on vertical, and the engine wasn't revving up over 10 on the ground. Another good choice is the OS 160 2 stroke. It's got just as much, if not more power than the 180. It sounds almost like a gas engine too.
Old 10-04-2002 | 08:10 PM
My Feedback: (12)
renn,
i will be getting the H9 edge and putting my YS 140fz in it. same rated HP as the OS180.
wondering as to what prop to use as well. you and i will have similiar setups it seems.
Old 10-07-2002 | 05:35 PM
Your prop is too big. Go with Something like a 16X10.
Old 10-08-2002 | 08:35 PM
the 18X 8 is listed as a sport prop. Oh well. The Edge I saw with the 160 has a 16X10, and it had ALOT of power.
Old 10-10-2002 | 12:14 AM
Shortman's Avatar
My Feedback: (21)
Default h9 edge 540 engine
I also have a H9 edge 540, I chose the OS 1.60FX with a Mejzlik 18 x 6 prop and Jett-In-Cowl muffler
Old 10-10-2002 | 06:27 PM
RCU-Admin's Avatar
Hey Guys,
With all the great information you have on this kit, add your two cents to the Product Profile we have: Right Here. Add build, power and setup tips, rate the thing and suggest compatible engines and radio equipment.
Help build our database of knowledge by contributing these items in the Product Guide, where pilots will be able to retrieve the information easily for years to come.
If you are the individual that posted the question, there are some ratings and engine recommendations you can look at in the product guide. Just click the link above.
Old 10-10-2002 | 06:56 PM
tailskid's Avatar
My Feedback: (34)
My son flew 'mine' all summer with a Moki 1.8 - nice combo, but could use a bit more - bet a Moki 2.1 might be perfect[img]i/expressions/face-icon-small-happy.gif[/img]
Jerry
Old 10-11-2002 | 10:22 AM
My brother has one and he's tried the Moki2.10, OS1.60, and now finally the Moki 1.80. With the Moki 2.10 it wouldn't waterfall and it would tip stall on landing if too slow (over wingloaded), on the OS it would waterfall super tight but didn't have quite the long straight uplines for IMAC. The Moki 1.80 is the perfect engine for this airframe in our experience. It will Waterfall real tight, flat inverted spin, land at a crawl, and he can take it off, pull to a vertical upline, and you can watch in amazement as it will accelerate upward out of site. It is absolutely awesome. His prop is a Mejlick 19*8 Carbon Fiber. We are about 7-800 feet above sea level I believe.
