 ModelTech magic 3d >
ModelTech magic 3d
ModelTech magic 3d
Old 09-16-2008 | 07:42 PM
Default ModelTech magic 3d
Hi ModelTech Magic fans;
I have been flying the old version of the Magic 3D for some time now and have worn two of them out. I have now assembled and flown the new version (V2). The pull-pull cables vs steel push rods are a needed improvement. My main reason for writing this is to warn you of the new bolt on wing. While getting ready to epoxy the stabilizer to the fuse, I mounted the wing to ensure accurate placement of
the stabilizer. One of the wing bolts slipped completely through the wing and threaded bolt holes, the other fit so loosely that I was afraid to try and tighten it sufficiently to hold the wing in place. My fix was to glue a wooden block under each side of the wing mount,
retap the holes to 1/4-20 and use the larger nylon bolts. The plane flys every bit as good as the original, maybe better.
Sonnytex
Old 09-16-2008 | 10:10 PM
My Feedback: (15)
Default RE: ModelTech magic 3d
Hi SunnyT,.. what engine do you have on yours? I just assembled one, the old version, and have a Thunder Tiger 46 pro on it.Im using a funfly prop, an APC 12.25x3.75 and just cant find the sweetspot to get it to hover(if it will even do it) . Of course my 3D skills are lacking as well [sm=drowning.gif]
John
Old 09-17-2008 | 03:08 AM
Salty25's Avatar
My Feedback: (9)
One of the selling points for this plane was that it will hover with a .46 engine. Maybe you have the CG too far forward. The CG has to be back to get a good hover going.
Old 09-17-2008 | 09:00 AM
My Feedback: (15)
Actually I did have the suggested cg rearward a little by placing 2 and 1/2 oz of lead ( the dreaded word, lol) in the back of the fuse, but didnt like the way it handled so I removed about one oz from that. It just seems to fall off to one side rather quickly,... maybe its just me(?)
John
Old 09-19-2008 | 12:37 PM
John,
Sorry to take so long to get back to you. Your TT .46 should be plenty of engine for about any manuver you want to do with your Magic 3D. I had a .46 OS fx on one plane and a .46 OS AX on the other. Both engines would take it out of sight vertically, no problem. I now have a TT 54 4-stroke on the new plane and it too is plenty of engine. The OS .46's do pull it better though. I tend to stick with an 11x5 or 11x6 on all of these engines since they tend to spool up faster than using a 12 inch which gives a little better control of 3D efforts.
Sonnytex
Old 09-19-2008 | 05:00 PM
microsprint9's Avatar
My TT PRO.46 liked the APC 12x4 much better than the 12.25x3.75, it spools up quicker and would hover my 5lb Twist no problem.
Old 09-19-2008 | 05:39 PM
mclina's Avatar
I recently won one of these at a club raffle. I am planning on retiring one of my SPADs and swiping all the gear for this plane. The engine is an OS .46LA. How do you think it will fly? I do not fly 3D, I just want a fun flying aerobat.
Old 09-19-2008 | 07:07 PM
mclina,
The .46LA should work just fine - the AX/FX are stronger engines but the LA is still good enuf. This is a very light plane and
a 46 is at the upper end of suggested engines.
Sonnytex
Old 09-19-2008 | 09:55 PM
My Feedback: (15)
Thanks for the reply SonnyT, Im going out to the field tomorrow morning and going to try changing the props and give it a whirl... will report back to you.
Old 10-01-2008 | 12:31 PM
mclina's Avatar
ORIGINAL: mclina
I decided I wanted to go electric instead. I have the plane all ready to fly, hopefully I can maiden it this Friday.
I went with this motor:
http://www.hobbycity.com/hobbycity/s...idProduct=3887
With a 45 amp ESC. I have a 3S 2150mAh LiPo in it, with a 10x5 prop, and it pulls like crazy. I cannot wait to try it out.
My all up weight came out at about 3.24 pounds.
I'll report back once I know how this setup flies.
Old 10-01-2008 | 04:56 PM
mclina's Avatar
Here's a couple of shots of the power system. The battery I stuck in for the photo is smaller than the one I plan on flying. I tested it this afternoon, and I got about 6 minutes at half throttle with the 2150 3S pack. I know that if I want to fly aggressively, I will need a larger pack.
I had to mount the motor 1.25" off the firewall to get it to balance. If I go to the larger battery, I just need to remove a spacer.
I also put on bigger tires to help it balance. The stock tires are very lightweight.
I guess I have plenty of prop clearance.
Still planning on a maiden this Friday....
ID:	1044492   Click image for larger version
ID:	1044493   Click image for larger version
ID:	1044494   Click image for larger version
Old 10-06-2008 | 11:36 AM
mclina's Avatar
I have now flown this plane seven flights, and it is a blast. My first trip to the field was a bit windy, and I didn't bring an assistant to time my flights, but I got in four flights.
It was a tad tail heavy with the 2150mAh pack, but it climbed like mad, and fought the wind pretty well. While I was recharging the 2150 pack, I stuck BOTH of my 1550mAh 3S packs in the plane and plugged them in one at a time. Obviously, the flights were pretty short, but still fun, and the plane balanced much better. After the 2150 pack recharged, I strapped two AA batteries to it for added weight and took it back up. It was really windy by then, but very fun to fly.
When I went home, I soldered up a Y harness so I could run the two 1550 mAh packs in parallel. I also added spacers to move the motor forward by 1/4".
I went back to the field again yesterday, with no wind, and with my trusty 10 year old assistant armed with a stopwatch.
I flew the 2150mAh pack, with a few extended vertical climbs, for just under 6 minutes.
I flew again with the two 1550mAh packs in parallel. Got the same perfomance, and had a flight of a few seconds short of 9 minutes.
After about a 30 minute charge on the 2150 pack, at 3 amps, I took it up for another six minute flight. It just gets more fun every flight.
In summary, we were at the field for just under an hour, I got in two six minute flights and one 9 minute flight. I am trying to decide if I should buy a couple more 2150 packs for $20 each, or four more 1550 packs for $15 each. I looked at ~3500mAh packs, but they are closer to $50 minimum. (These prices are all Zippy packs from Hobby City.)
Old 03-23-2009 | 12:53 AM
FlyFanatic's Avatar
I've been scratching my head trying to figure out a good way to replace that tail skid on a new version 2 arf build, any thoughts on a tail wheel mod? Anyone?
Old 03-23-2009 | 09:45 AM
FlyFanatic,
I put a tail wheel on my Magic (after it was assembled and flown a few times). I put a hole in the fuse at the bottom and ran the wheel
wire straight up at the point where it should normally fit into the rudder in a normal configuration. I then bent the wire 90 deg to the rear to position it like it would go into the rudder. I trimmed out a channel on the rudder the size of the wire (not completely thru the rudder but just enough to fit the wire. I then fit the wire in the rudder, put some expoxy to fill the channel and let it dry. I then got two control horn bases and put one on each side of the rudder (screwed to each other) to hold it firm. Finally, I mounted the plastic wheel mount to the fuse with screws. Be sure to put a little thin CA into each hole to toughen them. Doing this takes a little patients due to the fact the rudder is always in the way but the tail wheel wire will bend enough to let you get it done. I probably have over 50-60 flights on the Magic since I installed the tail wheel and have had no problems.
Sonnytex
Old 03-23-2009 | 10:31 PM
balsabuster2003's Avatar
Ugly, but it works. Using a Klett-style tailwheel bracket.
Old 03-29-2009 | 03:11 AM
FlyFanatic's Avatar
Great info from you both, today I will be deciding which to do today... thanks! Any chance of a picture sonnytex?
balsabuster2003, did you use only one metal pushrod for the rudder? I'm debating on the the pull-pull for both ele/rud or one metal rod each.
Old 03-29-2009 | 07:45 AM
FlyFanatic,
I would stick with the pull-pull system - by the way the new version, V2, uses a cable pull-pull rather than the original steel pushrods. I am just now getting ready to go to the flying field . I will send you a picture this evening.
Sonnytex
Old 03-29-2009 | 05:39 PM
FlyFanitic,
These are not the greatest pictures but you should get the idea.
Sonnytex
ID:	1168739   Click image for larger version
ID:	1168740   Click image for larger version
Old 03-29-2009 | 06:53 PM
FlyFanatic's Avatar
Sonnytex, great pictures, It looks that you offset the rod from center? That is my concern with the pull-pull tube dead center.
Old 03-29-2009 | 08:20 PM
FlyFanatic,
It does appear to be off slightly - I made this modification in the field after spending several hours trying to steer the plane in a 20mph wind. You can do a better job I'm sure. It makes a world of difference in how the plane handles on the ground. It has served me well for some time now.
Just so you don't think I wasted your time waiting for the pictures, I maidened my new "Somethin' Extra" today and it is as much, if not more, fun as my Magic.
Let me know how the mod goes - send me a pix if you can.
Sonnytex[sm=thumbs_up.gif]
Old 03-29-2009 | 11:24 PM
FlyFanatic's Avatar
Sonnytex,
I am 99% done with the magic, I have held off on the rudder to attempt the mod, I have had planes in the past with tail skids and always regretted not trying to mod it after the fact.
The magic is funfly plane number 2 in the hangar, after the twist and actually just acquired a somethin' extra rtf from a kit a guy was selling, it is the second SSE I have owned and it is
another good choice for funflys. The only thing other than the tail skid on the magic I do not like is the transparent covering, not good at all for orientation. Thanks for all the good info!
