 Setting cg on a low wing plane >
Old 10-17-2008 | 10:02 PM
show871's Avatar
Default Setting cg on a low wing plane
Do you cg a low wing plane canopy down, or canopy up?
Thanks 871
Old 10-17-2008 | 10:06 PM
rye
My Feedback: (10)
Default RE: Setting cg on a low wing plane
hi
i do all my low wings canopy down, thats the way all my club members do too
Old 10-17-2008 | 10:29 PM
ram3500-RCU's Avatar
My Feedback: (221)
CG will not change when inverted. CG is CG. It is just sometimes easier to balance the low wing plane inverted because more of the mass is below the balance points. I balance both ways for CG, whichever is easier given the size and shape of what I'm balancing. Lateral balancing I always do right side up because it is easier to hold the tail.
Old 10-17-2008 | 11:04 PM
MostlyKaos's Avatar
I balanced my Kaos both inverted and level and I could not see a difference. As mentioned above Lateral balance was done level and made a big difference in flight.
Old 10-17-2008 | 11:16 PM
show871's Avatar
Thanks! Yea, It holds its setting much better canapy down. Up, and it stays down on the tail or nose depending on which I push down......871
Old 10-17-2008 | 11:17 PM
aussiesteve's Avatar
I use this
Definitely the easiest of the lot.
[link]http://home.mindspring.com/~the-plumber/Vanessa%20CG%20Machine.htm[/link]
