 4*40 control rods? >
4*40 control rods?
4*40 control rods?
Old 11-05-2008 | 11:03 PM
My Feedback: (13)
Default 4*40 control rods?
how many have problems with the plastic control rods in the 4*40? have any changed them out? any trim differences?
Old 11-06-2008 | 08:53 PM
WMB
Default RE: 4*40 control rods?
I used Sullivan Golden rods because I had heard of the trim changes with the stock nyrods. The Golden rods did require trim changes as the temps changed. I flew this way for a few years and then tried the Sullivan carbon rods- no more trim changes.
Old 11-06-2008 | 10:10 PM
Ryan I.'s Avatar
I havent had any issues with the stock push rods that came with my 4* 40. They seem to do their job on a plane this small.
Old 11-07-2008 | 08:44 AM
Same here. Flew the 4* for 2 years, never noticed any trim change using the stock stuff. I think a lot of this " don't use the stock stuff" comes from the makers of the expensive stuff . Just like,the guy that first said" you should have bacon & eggs for breakfast" guess what,-He raised hogs & chickens !!!
Old 11-07-2008 | 05:42 PM
my 4* does have to be retrimed with tem change it the only plane that i have that needs it so must be something with the push rods
Old 11-07-2008 | 10:41 PM
My Feedback: (13)
Thanks, i will put 256 control rods in it.
Old 11-08-2008 | 08:34 AM
My Feedback: (7)
I had a kit built 4*60 a few years ago, and in the Texas heat, required a lot of retrimming when flown. Switched to a goldenrod version, and they worked fine. It's probably a climatic issue as to what result you might get.
Old 11-08-2008 | 06:33 PM
I've had the 40 and 60 size, i have experienced a little changeing. Nothing worth replaceing the control rod's over.
Just my $00.2 worth.
John
Old 11-08-2008 | 06:47 PM
w8ye's Avatar
My Feedback: (16)
I had a early 60 ARF that after seeing how the originals worked, I installed Golden Rods inside the original Sig outer tubes. What a pleasure. They worked perfect for the life of the plane.
Old 11-08-2008 | 09:03 PM
Put 2-56 into my Four * 40 ARF right from the beginning. I used the plastic for the throttle and notice I am always chasing a even idle.
Old 11-09-2008 | 06:40 AM
Hello
I was wondering if it is possible to adjust the length of the Sullivan rods? when i look at their web page they give me a specific length of the cables.
I'm new to model building so it's possible that the answer is given
Thomas
Old 11-09-2008 | 11:27 AM
w8ye's Avatar
My Feedback: (16)
They are cut with a hobby knife to length for the Golden Rods and all the plastic ones as far as that goes
