H9 Aresti 40 WheelPants / Engine >
Old 06-17-2003 | 06:15 PM
Default H9 Aresti 40 WheelPants / Engine
Does anybody have good instructions on how to put the wheel pants on the Aresti 40. I think I am going to need different ones, because I really screwed them up I think. How can I get different ones? Also is it possible to mount the engine in sideways instead of inverted ?
Old 06-17-2003 | 06:20 PM
I had a friend do the Wheel pants after ruining three of them. They are a pain in the rear if you follow the instructions.
You could probably mount the engine sideways however you would be dealing with it sticking out the side of the cowl since this is a thin plane. I use a Saito .56 on mine and it doesn't stick out of the bottom.
Old 06-17-2003 | 06:55 PM
How did you get new wheel pants?
