Vector Flight Edge 540?
CA
Originally posted by David_Moen
I guess one could apply some film trm to the bottom to jazz things up a little..
When instaling the Robart hinges on a "surface hinged" aileron, how close to the top surface do you need to drill the hole for the hinge? LE bevels are cut that way for film hinges, I wonder if mono/ultrakote hinges would work?
David, you got the Edge right? Does the Edge have a plastic bellypan like the Extra?
Have you flown yours yet?
I fitted the Robart hinges right into the edge of the aileron, angled downwards, so they are already bent when the aileron is straight. It seems to work well.
Mono/Ultrakote hinges? <gulp> If you mean use covering as a hinge material? I would definitely recommend you don't do it! It would be nowhere near strong enough for a model of this size.
Yes, I have the Edge, and yes there is a plastic belly pan. Not my favourite part of the design, but it seems pretty strong. I will be using brass inserts with 4-40 bolts, not screws.
I haven't flown it yet, but if you do a search for the Vector Edge, you will see Calflyer raves about it!
David C.
My Feedback: (68)
Originally posted by tsawyer148
I was planning on the 3004's. I have several of them lying around looking for a home...
T.
T.
good call.
by the way I recognized Eddy in your avatar from Iron Maiden!! Believe thats the poster from Aces High
ahhh the memories.. :bananahea
My Feedback: (8)
Yes DiabloKid,
I'm just another middle aged teenage dirtbag. Saw them two summers ago at the Aladdin in Las Vegas..Great show. Always liked the pic so it seemed to work for this.....
T.
T.
My Feedback: (68)
its ok I grew up on them, they are incredible! Only band that takes history lessons and turns them into epic 8 min metal songs, lol gotta love it!
Anyone notice the VectorFlight webpage now states the backlog of orders has gone from 7 days to almost 2 weeks. Im glad to see a smaller company stay busy with a good product. I just cant wait until they ctach up alower their prices again so I can get one
#32
My Feedback: (8)
Rush, Def Leppard, Ozzy (pre-MTV ozzy, when his brain cells were still being destroyed, not completely gone), Judas Priest.....My son and I argue over what "Metal" really is....
T.
T.
#33
CA
Originally posted by Calflyer
Oh Yeah! Iron Maiden, Van Halen, Black Sabbath, Deep Purple, Pink Floyd, not neceserily in that order, excellent and definitive!
With the exception of Eddie Van Halen, who is Dutch, but lived in Pasadena, all the groups you mentioned are British!
The British invasion eh?
-David C.
#34
CA
And so are Uriah Heep, Genesis, Beatles, John Lennon, and Alan Parsons Project. No reason other than the music itself. Americans have their greats too, who can forget the Dead, Eagles, America and Tom Petty, Billy Joel, Simon and Garfunkel, Fleetwood and Jazz masters, and countless others!
#35
CA
The inspiration for most of these groups was American.
-DC
#36
I got my edge back together and added some tail weight to fix the CG problem. Plane flew great. I could hover the plane at just about 1/2 throttle and pull out with ease. The plane flew awesome until one of the club members took my plane out while hovering the plane. I am getting another one as these planes are awesome. I hope this helps inspire some folks.
-Brian West
-Brian West
#37
CA
-Brian West
-Brian West
Took it out?
Argh! that's a shame!
Still, it flew well until then? Hope you have better luck with the next one.
Mine still isn't built yet, as I'm still clearing space for it.
-David C.
#39
1 Post
Hingeing question again....Vecto tech support says they supply CA hinges with the planes, but don't install them so you have the option of using something else. Do they cut slots for the CA hinges provided?
Also, has anyone flown the 66" Extra? Lots of noise on RCU regarding the Edge, but I like the looks of the Extra better and it seems (from the VF website) that the Extra comes out a bit lighter. My primary interest is IMAC style aerobatic flying, although a bit o' 3D would be fun too!
#40
CA
Hi David,
Vector supply CA hinges, but I didn't notice the slots had been cut. As I say, I used Robart pin hinges which were very easy to install and are extremely strong.
-David C.
-David C.
#41
Good Luck,
Dave Olson
#42
CA
That sounds like too much fun! hovering at 1/2 throttle! My Vector 540 is a rocket with a 91FX but havent tried low level hovering yet. I am trying to take it way up and pulling into the hover position and it seems to respond well without any problems. Most times I am just having a ball with flinging this plane around. It responds lightning fast and crisp, sort of like a very precise sports car. Maybe has to do something with the strong airframe and wings.
#43
1 Post
Actually I rec'd an e-mail from Vector this morning. They said they would pre-cut CA hinge slots for me at no charge if I requested it at the time of order. Although I like the idea of the robart hinges, I've never used them and I doubt my abilty to get them mounted properly on the pre-beveled control surfaces. As VF used to sell the planes with the control surfaces pre-hinged with CA hinges, tehy must have the tooling set up for this already so they should be perfect!
#45
1 Post
VF tells me that they like CA hinges, and used to use them in production, but for some reason CA hinges had a bad name early on and people used to cut them out and replace them, so they stopped installing them at the factory.
#46
FL
#50
CA
Guys, Ive flown both and they are both very fine flying airplanes, I would actually say easy with reduced rates. Both slow down a lot if you just want to take it easy at first, but turn them loose and they can create a big riot!! Dont think you can go wrong with either one.
Nice pictures cooter!
