KMP's L-4 Grasshopper
Hello Zippi The KMP L-4 I have is not solartex covered. It is clear film which has been painted. Granted at first glance I mistook it for fabric, mostly because the add said it was fabric covered. I have found a few things wrong with the plane which I contacted Andrew Kondor about. He got back to me right away, and thanked me for the info. But as for the matter of the covering. I haven't heard a thing. It has only been two days, so I'll give it some time. A friend of mine also has one and as soon as he gets back from vacation that one will be checked. I know these 2 L-4s are first run. Not a excuse to me. I like to think the best of people and maybe the folks at CMPro pulled a fast one on Andrew. I hope KMP finds a way to make this right. 1(POed)builder
NC
Another thought for you all. I have been dealing with the Chinese for about 20 years in many different fields. As you have seen from many building manuals, theres a lot to be said about the translation. What I mean is that the Chinese will say covering painted to simulate fabric and the translation we read actually says painted fabric. It happens all the time in other industries. I believe the issue warrants that in the future, Andrew Kondor should get a demo or sample and proof the marketing if this is the case. Just a thought. Bob
My Feedback: (10)
ORIGINAL: insyt21st
#31
NC
Update on the H-9 gear. After some flights it was evident that it was way to stiff for the plane being that the Grasshopper weighs about 5 lbs less than the H-9 Cub. Remedy!! Did incision on booty opposite seam and removed one of the two springs on each side then, sewed it back up. It functions perfect now for the CMP Cub / Grasshopper Very flexible!!
#32
UT
Bob, That H-9 Cub gear was quite a bit of a modification to do. One strut was too long and had to be shortened a quarter inch and then re-drilled to mount. Certainly is much stiffer than the CMPro gear also it now traks like a normal Cub does on take-off and landings. Oh well, This one wont crack at welds so it should be around for some time. What's next ? MM
#33
NC
I had to take off 12mm of each strut and re drill . look at my previous reply above about the springs. Mine now traks great, no different from the old gear
#34
We have gotton a bit off track here. I just want everyone to know the KMP L-4 has a lot of issues. I have assembled ARF's from Great Planes, Hanger 9, and several others. From those vendor I got what was advertised. I just want everyone to know. I also see KMP has changed it's web ad from "beautiful fabric covering" to "beautiful covering". Doesn't do anything for those of us that thought we were buying a fabric covered plane. I can live with the other defects. I'm sure it will be a nice plane. One last thought, the rocket tubes are way to big. If you want to know more about this plane feel free to contact me. 1builder (except KMP planes)
