 DX6i Flaps >
DX6i Flaps
DX6i Flaps
Old 02-20-2011 | 02:29 PM
Default DX6i Flaps
Does anyone have insturction on how to setup flaps on the DX6i Radio?
Old 02-20-2011 | 06:51 PM
pipercub4's Avatar
Default RE: DX6i Flaps
It depends. Do you have a receiver that has an input for flaps or are you planning to use an AUX channel?
Old 02-20-2011 | 07:11 PM
Yes, I have a flaps option in my menu.
Old 02-20-2011 | 11:52 PM
I'm pretty sure that you have to go into the settings and enable them by setting the amount of flap (%) you want once you hit the switch (and any elevator adjustment if you want that also).
It's in the manual isn't it? (not read mine that heavily for planes)
Old 02-21-2011 | 06:31 AM
pipercub4's Avatar
Yeah, there is a page on it in the manual.
Old 05-10-2013 | 04:47 AM
I am new to RC planes and have funcub with a <h1 style="margin-bottom: 0px; margin-top: 0px;" class="parseasinTitle "><span id="btAsinTitle"><font face="Arial, Helvetica, sans-serif"><font size="4"><span style="font-weight: normal;">Spektrum Ar6115E 6-Channel DSMX Microlite and dx61 radio. No channel for flaps on Rx but I have it working with gear. trouble is I don't know how to use the flaps </span></font><span style="font-weight: normal;"><font size="4">switch on radio and to mix elevator. Can anyone help?</font></span></font></span></h1>
Old 05-10-2013 | 06:26 AM
Charlie P.'s Avatar
There is no "flaps" channel on any receiver. You either use two ailerons in seperate jacks and they work as flaperons or you use dedicated flaps in the Gear or one of the Auxiliary jacks.
Note it can't be done if you use a "Y"for two servos or only have one aileron servo.
On the Model list go to the Flaps selection and assign how much elevator you want to add in. You have to set the switch to the LAND" choice (landing) and enter how much elevator you want. Try no more than 5% at a time.
It's page 15 of the manual.
Old 05-10-2013 | 09:03 AM
Perfect jsut what I was looking for... Used a reversing y harness in aux channel... 25% down elevator in flap landing mode.. works well so far...
Old 05-12-2013 | 11:21 PM
I do think you have to take it OFF inhibit or 'INH' on the screen first, then it's a matter of setting the overall level you want them to come down with the percentage.
You can also add some elevator trim mixing too
Old 05-13-2013 | 04:56 PM
KitBuilder's Avatar
mixing shmixing....does nobody fly anymore
Old 05-13-2013 | 11:33 PM
The correct answer is that we do indeed fly, it's just now day's we tend to fly smarter.
Old 05-14-2013 | 07:04 AM
ORIGINAL: KitBuilder
I'm with you on this one. I like to fly without mixes, like manually using rudder to coordinate turns, or knowing how to usejust the right amount of down elevator when I deploy flaps. Iuse dual rates but don't like expo. To each his own Iguess.
