Advice needed
Howdy everyone,
Iam trying to get back into RCplanes and need help figuring out which plane to get. Ihave flown a trainer a while back so Iknow the basics. Would like to step up to the next level and am trying to decide on a plane. Ihave been thinking about a Super Sportster 40 or the Escapade either in 40 or 60 size. Iprefer the larger size as there is always wind out here. Am looking for a lower wing model that still handles somewhat easy. Idid make the mistake a couple of years ago of getting an electric Edge 540. Found out quick that it was a bit more than Icould handle. Would these two planes be a fairly decent next step from a trainer and is there other planes Imight should look at? Thanks in advance for any help ya'll might can give me.
WT
WT
those are both very good ships as a second ship another plan bisic would be a ugly stik but it is mid wing and are alot more fun due to you can go tricycle or tail dragger just my 2 cents ok
If you want a low wing plane the two standard suggestions you'll see over and over are the Sig 4 Star and the Goldberg Tiger II. They are purpose built to be forgiving 2nd planes with low wing maneuverability. I've even known of one guy who trained on a 4 star.
You can't go wrong with a Big Stick. It's fun to fly, does great aerobatics and lands as slow as a trainer.
My 40 landed much smoother than my actual trainer. That's why they are so popular
I agree on the Sticks. I wished I had trained on one because they are easier to fly than any trainer is. But the OP said he wanted a low wing plane, which is why I recommended the 4 Star and Tiger. If you want something scale, you might consider a Ryan PT19/PT20 or a T28 Trojan. Both were originally military trainers and as models are fairly docile.
Thanks for everyone's advice, I will look into these other planes. I have about a month to decide and will take the time to look them all up.
Thanks again,
WT
Thanks again,
WT
Stik, Stik, Stik...
It goes from Mild to Wild and Back at a flip of a switch.
It does well in winds, it is easy to repair, rugged, and a blast at fun fly events!
