Reload this Page >
Wheels On Starting Stand
Old 06-28-2011, 02:17 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Default Wheels On Starting Stand
how would i go about installing wheels on a starting stand? im pretty crafty, but would like some input/ideas i found this pic here on RCU
just drill a hole and put a bolt, washers and a nut? or am i missing something?
Old 06-28-2011, 03:36 PM
bingo field
bingo field's Avatar
Default RE: Wheels On Starting Stand
Looks like lawnmower wheels, so yes, your idea should work. Without them , they would be a little tough to move to mow around.
Old 06-28-2011, 03:41 PM
MetallicaJunkie
ORIGINAL: bingo field
that's for sure
Old 06-28-2011, 03:55 PM
goirish
goirish's Avatar
ORIGINAL: MetallicaJunkie
Nope you are not missing anything. I would put a little bigger wheel than the one shown.. We have 7 of them at our field and they all have I believe 8" wheels.
Old 06-28-2011, 04:10 PM
CGRetired
CGRetired's Avatar
Geeeeezzz... You know, this is one of those "I wish I though of that" moments. I can't count the number of times I dragged the darned stands around at our field and thought "there must be a better way"... and of course, it was right there under my nose.
Ah well, you know, necessity is the mother of invention. I guess perhaps I'm an orphan or something... [X(]
CGr
Old 06-28-2011, 04:39 PM
goirish
goirish's Avatar
ORIGINAL: CGRetired
Geeeeezzz... You know, this is one of those ''I wish I though of that'' moments. I can't count the number of times I dragged the darned stands around at our field and thought ''there must be a better way''... and of course, it was right there under my nose.
CGr
CG, that is why you are fit as a fiddle. All that exercise lugging that thing around[8D]
Old 06-28-2011, 04:40 PM
Lnewqban
Lnewqban's Avatar
Yes, you are,.........add one more nut.
Old 06-28-2011, 05:24 PM
Charlie P.
Charlie P.'s Avatar
That's what we have so they can be wheeled into the pavilion at night..
ID:	1629040   Click image for larger version
Old 06-28-2011, 05:27 PM
MetallicaJunkie
ORIGINAL: Lnewqban
where would i put it?
Old 06-28-2011, 05:29 PM
goirish
goirish's Avatar
use it like a jam nut. That way when you roll it around, the nut doesn't come loose. Nothing worse than a loose nut
Old 06-28-2011, 05:30 PM
MetallicaJunkie
good idea.....i need to think of how i will tighten them without causing the wheels to lock up from over tightening
Old 06-28-2011, 05:36 PM
Lnewqban
Lnewqban's Avatar
See the schematic.
Both nuts press the wood, while the wheel has some axial play.
You can also use a sleeve between the bolt and the wheel if fit is too loose.
Best luck with the project.
Old 06-28-2011, 06:47 PM
MetallicaJunkie
ORIGINAL: Lnewqban
See the schematic.
thanks a bunch!!
nice stands Charlie
Old 06-28-2011, 07:39 PM
Gray Beard
My Feedback: (-1)
Just a heads up about stands. The photo is of a couple of the club members using one of our stands. We started out with the wooden type I think the instructions were in model Aviation? Then a club member started making them out of metal. At first we only had a couple so he added wheels so we could move them around, really heavy!! The back center section also is able to be extended for longer planes.
One thing we discovered about them, you put a big gasser on one it can flip even one of these over, the couple we had with wheels went over even quicker. Make sure the two vertical rails are tall enough for Bipes. We only had a couple of them I was able to use during my bipe days due to the rails and if I didn't get one with the extended center planes like my Tiger Moth were too long for them.
These stands are one of the things I really miss these days. They make an old guys life a lot easier and less painfull.
Old 06-29-2011, 08:58 AM
Instructor
My Feedback: (16)
Instructor's Avatar
We have at least ten of them at our field. Before you just insert a bolt, you need to add some type of spacer to the vertical leg just above the wheel, a little wider than the wheel you plan on using. This could be a small piece of 2X4. Take another piece of 2X4 and bolt it or screw it to the spacer. This piece needs to be long enough so the bolt you are using as an axel goes through it, the wheel and the vertical leg the wheel is attached to. This will keep the bolt or axel form elongating the hole in the vertical leg. This is the way we built ours. We have had them about 5 years now and the wheel is just a solid as the day we made them. Hopes this helps......
Larry
Old 06-29-2011, 10:43 AM
raptureboy
raptureboy's Avatar
No need for wheels, we put squares of astro turf under the stands pinned down with landscape staples and now we don't have to mow around them and if you drop a screw or something you are more likely to find it.
Old 06-29-2011, 12:04 PM
Gooseman240
Gooseman240's Avatar
Wow, lot of great ideas. So for the astro turf, do you spray some kill all to get a nice brown area on the edge of the astro?
