How to repair elevator....
MB, CANADA
Hi, the other day I was flying my Goldberg anniversary cub and in flight the wooden dowel rod connecting the elevator
halves snapped. I managed to land it ok i think, scraped the nose of the plane and that's about it.
Any way i was wondering if there is a better system to join the elevator halves.
As is stated replace wooden connector with metal. Use a piece of about 3/32 piano wire. Bend both ends 90 degrees. insert in holes drilled in each elev. about 3 inchers apart. In other words 90 degree bends shall be 3"apart or more. Be sure both bends are perfectly parrallel to each other. This is thr most common and best method.
My Feedback: (-1)
One of the CG Cubs I finished building for a friend just a short time ago. I never use an attached elevator, all the ones I build have a split elevator and I either use the two servos for the left and right or in this case I made up a push rod with two control rods or also known as a Y push rod. This one is made from a carbon fiber arrow shaft. Just a single rod on one end and the Y on the other. In case one of the control horns breaks you still have the other half working as usual. I have had the nylon control horns break on both a Y and a duel servo set up. Last one to break was on a stunt plane, only thing I noticed in flight was the plane wasn't as responsive as it usually is. I landed and spotted the problem right away. Two is always better then one. It's very easy to do too. This is a photo of a very happy owner.
On the wire... WHen building, I also clamshell from the front the wire inserts in the wood with some very lighweightg fiberglass maybe 1/4" beyond the end of the wire and and 3/4 inch or so centered on the wire insert. I beef this area up on all my planes as its the one control surface you pretty much can't do without.
