Engine Mount for a Test Stand
CA
Hi All,
I found this engine mount on the web.
It is the simplest I have seen and very reasonably priced.
Unfortunately, it is in the UK.
Does anyone know of a US supplier?
http://www.modelshops.org/model-engi...test-stand.php
KW_Counter
KW_Counter
Looks like that could easily be made with some supplies from a local hardware store. Ingenius indeed! I'll have to print this out and build one.
ORIGINAL: KW_Counter
Speed Demon,
Look like you need to make 3.
KW_Counter
Speed Demon,
KW_Counter
Really looks like a nice piece of 1/4" aluminum flat stock and a few bolts and a tap set would do the trick. Oh yeah...a nice mounted vise to do the bending.
Really... Id say less than 5 bucks to make.
http://www.lowes.com/ProductDisplay?...&cId=PDIO1
I know this piece of flat bar is more than 12 dollars. But that would make half a dozen of these things! Lowes does sell it in shorter, cheaper lengths.
CA
Yeah, they would be easy to make;
even easier if my brother hadn't sold the milling machine!
I made a real nice one years ago with a soft mount.
Unfortunately, I have some 4-strokes that won't fit on it.
I'll get something going soon.
Good Luck,
KW_Counter
Good Luck,
KW_Counter
