Engine Questions
Pencil protectors and minute calculations aside, the 3/8-1/2 inch of fuel tube wouldn't make any difference here. Air is not a solid, and we are not talking mach speeds.
Thanks for the input, however.
I suppose the lag time or lack thereof is perceptual. In fact, when I read Ed's post, I percieved him to mean length of tube between the NV and the carb = lag time.
If indeed we find any lag time, it is sooooo small, it really doesn't make any difference.
Remote NV = O-Tay.
Well done, Abraxxas!
Jetts
Remote NV = O-Tay.
Jetts
WOW...... massive amounts of posts while i was at work
ok, that time delay from the NV adjustment to the effect of that adjustment wouldn't really matter would it?.... i mean, you don't adjust the needle valve in mid flight. you're on the ground with an RPM gauge waiting for the RPMs to change ... waiting being the key word.... plus, i can wait a half a second for the flow change if it means making those changes is safer for someone prone to clumsiness, and the looks of the plane of better
ok, about the cowling i was thinking of building onto my trainer (after a while of flying it, just to have a test bed for the act of constructing one before i go ahead and do as i'm planning with my second plane).... air intake will be a 2 inch wooden dowl cut in half longways (to make 2 half circle yet long pieces), then carve out the middle to make something like a pipe. that would be about 1 and 3/4ths inches intake "surface area" (it's really anti-surface area since we're talking about gaps or cutouts
). the outlet would be a 1/2 inch gap between the bottom of the firewall and the bottom lip of the cowling..... with a 4 inch wide firewall that would mean 2" of outlet. not quite 150% (2" to 1 3/4" is about 114%) but def enough of a difference in surface area to cause the suction.
thanks for all of your time guys, and the great info
Rob
. ok, that time delay from the NV adjustment to the effect of that adjustment wouldn't really matter would it?.... i mean, you don't adjust the needle valve in mid flight. you're on the ground with an RPM gauge waiting for the RPMs to change ... waiting being the key word.... plus, i can wait a half a second for the flow change if it means making those changes is safer for someone prone to clumsiness, and the looks of the plane of better
). the outlet would be a 1/2 inch gap between the bottom of the firewall and the bottom lip of the cowling..... with a 4 inch wide firewall that would mean 2" of outlet. not quite 150% (2" to 1 3/4" is about 114%) but def enough of a difference in surface area to cause the suction. thanks for all of your time guys, and the great info
Rob
The small diameter tubing that was used to convey the pressure information to the actual sensors introduced a phase lag [my italics] in the pitot-static system that eventually coupled into the Flight Control Computer... however, once the pitot tube pneumatic lines were increased in size, the pressure lags disappeared...
Wings
#32
ORIGINAL: fledermaus
As for the remote needle valve, I vote for no delay. The pressure change down stream of the valve happens immediately for all intents and purposes, and that's what matters insofar as flow at the carb is concerned.
edit: added "... pressure waves of ..."
#33
MB, CANADA
With regard to fuel flows -
I agree with the consensus that there is no macroscopically detectable lag in response in a typical model situation. This was an interesting side issue on the main discussion, and I simply threw in the comment from the book because it was somewhat apropos.
Not intending to confuse things or to challenge empirical observation...
#36
FL
OK, well I'm not here to argue theory or the why's of it happening. But, my engines with remote needles DO lag in response to needle changes. As I said, it's more than one engine in more than one airplane and they all do it. Point being that nobody is going to convince me that I'm imagining things.
But the bottom line is that I'm aware of it, so it doesn't really matter. I just turn the needle slower and give the engine time to catch up.
#37
CM,
Just curious, do all your engines have remote NV's?
All engines of any size/fuel type ect. have some lag time after making setting changes. Remote NV's or not.
Have you tried side by side testing of lag time with the same engine with both types of NV?
Not saying you are imagining things, just asking what you are basing your observations on.
The reason this all started was Ed Moorman implied that with a remote NV the "lag time" was increased, which is simply not true, and so I was just trying to clarify things so people wouldn't think if they placed a NV "upstream" the tuning, or tunability would be affected.
As stated I have had some looong distances between NV and carb, with no adverse affects, including "increased lag time".
Yes- I have done side by side tests, just to make sure my extremely long fuel line between the two would work.
Jetts
Jetts
#38
I recalled seeing this on Jett Engineering's web site, re remote needle valves:
http://www.jettengineering.com/faq.html#faq7
#40
FL
My credentials? Take a look: [link=http://www.airfieldmodels.com]Airfield Models[/link]
30+ years of running probably 100 different engines on 100's of airplanes. Most of the engines I've owned have not had remote needles. If you're wondering whether or not I don't like remote needles, the answer is I don't care either way. Some of my aircraft did have different engines mounted at different times which is one of the things that made me take notice of the phenomenon in the first place.
But, if an article on the internet says that the wall I painted blue is white even though it's never seen my wall, I guess it's right.
ORIGINAL: jettstarblue
CM,
Jetts
CM,
Jetts
#41
ohh.... I put the Jett link there because of the reputation of Mr. Dub Jett. I assumed, incorrectly, that most would recognize the source of the information and judge it in that light.
#42
CM, ROGER THAT!
Jetts
P.S. your "phenomenon" is in the definite minority.[sm=drowning.gif]
CM, ROGER THAT!
Jetts
#43
FL
CM, ROGER THAT!
Jetts
CM, ROGER THAT!
Jetts
#47
FL
CM, O.K. you win, I'm bored, I think the point has been driven into the ground.......
Agreed, but that's not what my last comment was about. It was referring to my previous comment.
