 Acronyms for beginners >
Old 12-03-2003 | 01:15 PM
Default RE: Acronyms for beginners
FOD - foregin Object displacement
FORD - Found on road dead / fix or repair daily
FIAT - Fix it again Tony
Pontiac - Poor old knucklehead thinks it's a cadillac
Old 12-03-2003 | 03:50 PM
What about spars, Ive read them somewhere before, what are they?
chris
Old 12-03-2003 | 04:29 PM
For thermal sailplanes there's 2 classes"
Lead Sleds = molded sailplanes, usually with just a little dihedral.
Gas Bags = polyhedral floater sailplanes with seriously bent wings.
Servos - BB - ball bearing, MG - metal gears.
Gluck.
Old 12-03-2003 | 05:00 PM
I thought MG was 'Machine Gun'?!
Old 12-03-2003 | 10:48 PM
Ford- FIRST On Race Day
SPAD-- Simple Plastic Aeroplane Design
Old 12-04-2003 | 08:11 AM
  #31
gus
ORIGINAL: jester125
chris
Spars are the long, strong, members in the wing that go from tip to root. Wings made of balsa seldom have balsa spars, the spars are normally of spruce, or basswood. There are normally two spars, one at the top side, and the other at the bottom. They are sometimes connected together with a sheet of balsa to make an 'I' beam type arrangement. The structure between the spars is called the "shear web". The shear web is supposed to have the wood grain running perpendicular to the spar, but this is seldom done in practice. In practice, when you build a wing, the wing ribs are attached to the leading edge, the spars, and the trailing edge.
Basically, if you take the thickest part of the wing, at the top there is a spar that runs the length of the wing, and at the bottom too.
This is taken from dictionary.com:
A main structural member in an airplane wing or a tail assembly that runs from tip to tip or from root to tip.
gus
Old 12-04-2003 | 09:35 AM
  #32
Thanks gus
