Maiden flight anxiety!
#51
TX
For FMS/Futaba, be sure and connect shield ground to shield ground in addtion to the pins.
ALSO, with some video cards, there is a IRQ (interupt) setting in regards to it sharing it with the parrallel port that has to be turned off. Search for it in the forums at FMS's site.
#52
its called,,(white knuckles) if your breathing during a first flight your not fly'n......ive been fly'n for 8 years and it still happens today....hehehehehehehe...get used to it....there will be alot more....
#55
My maiden flight anxiety is OVER!!!!
I have tasted the sweet taste of r/c flight. will report back on it soon, don't have the time now.
#56
ON, CANADA
Unfortunately my triplane's maiden wasn't. Trio of errors
1) Slightly tail heavy
2) Excessive elevator travel
3) reverse exponential (installed a Hitec radio in this plane, I normally fly JR, guess I got confused) :stupid:
Ah well, live and learn. It's an exciting video, I'll post it when I get it converted. Very little damage (managed to coax her to the tall grass) and she's just about ready to try again.... guess this will be 2nd maiden flight jitters?
#57
Have time now.
Well. it was a beautiful day for starters, couldn't have been any better. The guy I was flying with got his stick in the air an was throwing it around a lot, low passes and all, anyway, he handed the box over to me and without any problems ( except keeping constant speed and height) I completed a number of very accurate figure eights.
We then found out after refueling, that I had my Tx set up differently to his and that I had been using rudder the whole time, after seeing this I flew with the ailerons and hey, I could do straight rolls and everything, not bad for my second time on the stick. On the third flight i got a little more adventureous and went a bit lower and faster and did my first stall turn!!!. My dad came back from the farm next door and was very impressed and said " to much time on the simulator!" , that cracked everyone up.
Then it was time to take MY plane for a flight, my friend named it ' The Bomber', it is the skewest bi-plane ever, I let my flying friend take it up first to trim it out, boy did it need a lot of that. It hasn't been flown for 20 years, my dad used to fly them. The second t/o was not so successful as it stalled on t/o and a wing droped, caught the ground and rolled and fliped the plane, only damage, bent undercarage.
Third flight was more successful, got off clear after a longer t/o run than the previous. Then I flew some more figure eights, then handed it to my friend to see what he could do with it , well it rolls, very, very slooowwly. He did a fly-by and it is a little disconcerting when this plane flies straight at you but angeled out by 'bout 10 degrees. The reason for this is that the tail boom was glassed back on , but not too straight.
He then did a low pass, the engine quit and we lost site of it going around the bush, our "spectators" gave a cheer as it missed a tree and tumbled into the bush, no substantial damage apart from a brace that broke under the wing.
Damn what a cool day that was!!! I am now sooooooo hooked on the smell of the fuel and exhaust fumes and flying itself , probably go fly tomorrow, had to play golf today, shot an 88 ( par 71) so I am pleased wif that as well.
How I LOVE R/C.
Good flying
Ledz
How I LOVE R/C.
Good flying
Ledz
